错误如下:
Heaps are enabled, but the segment for DSP/BIOS Objects (MEM.BIOSOBJSEG) is not set correctly. Please create a heap in one of your data segments and set MEM.BIOSOBJSEG to it.
解决方案:
右键点击MEM-Memory section manager->properties ,你可以看到segment for DSP/BIOS Objects和segment for malloc()后跟的选项只有MEM_NULL,问题就出在这里,你可以将你所定义的MEM下的任一选项:SRAM,MSARAM等等,拿 MSARAM为例,右键MSRAM->properties 将"enter a user defined heap identifier lable "打勾,在"heap size"中输入大小,将"enter a user defined heap identifier label "打勾,在"heap identifier label "中输入任意堆栈名。点“应用”、“确定”。补充下,修改完MSARAM后,右键点击MEM-Memory section manager->properties ,你可以看到segment for DSP/BIOS Objects和segment for malloc()后跟的选项改为MSARAM即可
