用的是iar 6.10 ,在option中设置如下:
link->config->$TOOLKIT_DIR$\CONFIG\LPC2103_RAM.icf
(目录没有放错,本来是找的lpc2103_ram.xcl,试过结果一样)
debugger ->setup->driver中选的是jlink;
#include "nxp\iolpc2103.h"
#define LED2CON 1<<18
void main(void)
PINSEL0=0x00000000;
PINSEL1=0x00000000;
IODIR=LED2CON;
while(1)
IOSET=LED2CON;
IOCLR=LED2CON;
这个是网上找的,简单的。
以下是lpc2103_ram.xcl
// XLINK command file template for EWARM/ICCARM
// Usage: xlink -f lnkarm <your_object_file(s)>
// -s <program start label> <C/C++ runtime library>
// $Revision: 1.2 $
// Code segments - may be placed anywhere in memory.
// INTVEC -- Exception vector table.
// SWITAB -- Software interrupt vector table.
// ICODE -- Startup (cstartup) and exception code.
// DIFUNCT -- Dynamic initialization vectors used by C++.
// CODE -- Compiler generated code.
// CODE_I -- Compiler generated code declared __ramfunc (executes in RAM)
// CODE_ID -- Initializer for CODE_I (ROM).
// Data segments - may be placed anywhere in memory.
// CSTACK -- The stack used by C/C++ programs (system and user mode).
// IRQ_STACK -- The stack used by IRQ service routines.
// SVC_STACK -- The stack used in supervisor mode
// (Define other exception stacks as needed for
// FIQ, ABT, UND).
// HEAP -- The heap used by malloc and free in C and new and
// delete in C++.
// INITTAB -- Table containing addresses and sizes of segments that
// need to be initialized at startup (by cstartup).
// CHECKSUM -- The linker places checksum byte(s) in this segment,
// when the -J linker command line option is used.
// DATA_y -- Data objects.
// Where _y can be one of:
// _AN -- Holds uninitialized located objects, i.e. objects with
// an absolute location given by the @ operator or the
// #pragma location directive. Since these segments
// contain objects which already have a fixed address,
// they should not be mentioned in this linker command
// file.
// _C -- Constants (ROM).
// _I -- Initialized data (RAM).
// _ID -- The original content of _I (copied to _I by cstartup) (ROM).
// _N -- Uninitialized data (RAM).
// _Z -- Zero initialized data (RAM).
// Note: Be sure to use end values for the defined address ranges.
// Otherwise, the linker may allocate space outside the
// intended memory range.
// Inform the linker about the CPU family used.
-carm
// Segment placement - General information
// All numbers in the segment placement command lines below are interpreted
// as hexadecimal unless they are immediately preceded by a '.', which
// denotes decimal notation.
// When specifying the segment placement using the -P instead of the -Z
// option, the linker is free to split each segment into its segment parts
// and randomly place these parts within the given ranges in order to
// achieve a more efficient memory usage. One disadvantage, however, is
// that it is not possible to find the start or end address (using
// the assembler operators .sfb./.sfe.) of a segment which has been split
// and reformed.
// When generating an output file which is to be used for programming
// external ROM/Flash devices, the -M linker option is very useful
// (see xlink.pdf for details).
// Read-only segments mapped to ROM.
-DROMSTART=40000040
-DROMEND=40007FFF
// Address range for reset and exception
// vectors (INTVEC).
// The vector area is 32 bytes,
// an additional 32 bytes is allocated for the
// constant table used by ldr PC in cstartup.s79.
-Z(CODE)INTVEC=40000000-4000003f
// Startup code and exception routines (ICODE).
-Z(CODE)ICODE,DIFUNCT=ROMSTART-ROMEND
-Z(CODE)SWITAB=ROMSTART-ROMEND
// Code segments may be placed anywhere.
-Z(CODE)CODE=ROMSTART-ROMEND
// Original ROM location for __ramfunc code copied
// to and executed from RAM.
-Z(CONST)CODE_ID=ROMSTART-ROMEND
// Various constants and initializers.
-Z(CONST)INITTAB,DATA_ID,DATA_C=ROMSTART-ROMEND
-Z(CONST)CHECKSUM=ROMSTART-ROMEND
// Read/write segments mapped to RAM.
-DRAMSTART=40000040
-DRAMEND=40007FFF
// Data segments.
-Z(DATA)DATA_I,DATA_Z,DATA_N=RAMSTART-RAMEND
// __ramfunc code copied to and executed from RAM.
-Z(DATA)CODE_I=RAMSTART-RAMEND
// ICCARM produces code for __ramfunc functions in
// CODE_I segments. The -Q XLINK command line
// option redirects XLINK to emit the code in the
// CODE_ID segment instead, but to keep symbol and
// debug information associated with the CODE_I
// segment, where the code will execute.
-QCODE_I=CODE_ID
// Stack and heap segments.
-D_CSTACK_SIZE=200
-D_IRQ_STACK_SIZE=50
-D_FIR_STACK_SIZE=10
-D_SVC_STACK_SIZE=10
-D_ABT_STACK_SIZE=10
-D_UND_STACK_SIZE=10
-D_HEAP_SIZE=2000
-Z(DATA)CSTACK+_CSTACK_SIZE=RAMSTART-RAMEND
-Z(DATA)IRQ_STACK+_IRQ_STACK_SIZE=RAMSTART-RAMEND
-Z(DATA)FIR_STACK+_FIR_STACK_SIZE=RAMSTART-RAMEND
-Z(DATA)SVC_STACK+_SVC_STACK_SIZE=RAMSTART-RAMEND
-Z(DATA)ABT_STACK+_ABT_STACK_SIZE=RAMSTART-RAMEND
-Z(DATA)UND_STACK+_UND_STACK_SIZE=RAMSTART-RAMEND
-Z(DATA)HEAP+_HEAP_SIZE=RAMSTART-RAMEND
// ELF/DWARF support.
// Uncomment the line "-Felf" below to generate ELF/DWARF output.
// Available format specifiers are:
// "-yn": Suppress DWARF debug output
// "-yp": Multiple ELF program sections
// "-yas": Format suitable for debuggers from ARM Ltd (also sets -p flag)
// "-Felf" and the format specifiers can also be supplied directly as
// command line options, or selected from the Xlink Output tab in the
// IAR Embedded Workbench.
// -Felf
红字是显示错误的地方。
| OrangePiZero2W系统被打赏¥33元 | |
