电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » (SD卡+FATFS,进行中)zangchao ARM DIY进程帖
共124条 9/13 |‹ ‹ 7 8 9 10 11 12 › ›| 跳转至页
2012-04-26 23:58:48     打赏
81楼
啊?是么,我看看,要是代码有问题,我考完后再试试。
2012-05-01 12:18:57     打赏
82楼
请问全部器件收集完,需要多少钱呢?谢谢
2012-05-01 13:19:35     打赏
83楼
由于器件多是贴片,一般都是100个一组发,你要是自己买的话,板子上的器件大约在130左右吧
2012-05-02 11:15:24     打赏
84楼
其实电阻电容很便宜的,把常用的贴片阻容每种买100个,也花不了多少钱
2012-05-02 20:12:26     打赏
85楼
对。要是同学也申请了,其实这些基础元件可以够两个人用的,这样成本就会降下来,我就是买了一套基本件,和同学共用的。
2012-05-06 20:59:36     打赏
86楼
CAN回环模式测试代码
#include "stm32f10x.h"
#include "delay.h"
typedef enum {FAILED = 0, PASSED = !FAILED} TestStatus;
vu32 ret; /* for return of the interrupt handling */
volatile TestStatus TestRx;
ErrorStatus HSEStartUpStatus;
TestStatus CAN_Polling(void);
TestStatus CAN_Interrupt(void);
void GPIO_Configuration(void)
 GPIO_InitTypeDef GPIO_InitStructure;
   /* Configure PE.02, PE.03, PE.04 and PE.05 LED as Output push-pull */
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
   GPIO_Init(GPIOE, &GPIO_InitStructure);
   /* Configure CAN pin: RX PB8*/
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
   GPIO_Init(GPIOD, &GPIO_InitStructure);
   /* Configure CAN pin: TX PB9*/
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
 GPIO_PinRemapConfig(GPIO_Remap2_CAN1, ENABLE );    //重影射CAN IO脚到 PB8,PB9
 GPIO_SetBits(GPIOE, GPIO_Pin_2);
 GPIO_SetBits(GPIOE, GPIO_Pin_3);
 GPIO_SetBits(GPIOE, GPIO_Pin_5);
 GPIO_SetBits(GPIOE, GPIO_Pin_4);
//系统中断管理
void NVIC_Configuration(void)
 NVIC_InitTypeDef NVIC_InitStructure;
   /* Configure the NVIC Preemption Priority Bits */
   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
 #ifdef  VECT_TAB_RAM
   /* Set the Vector Table base location at 0x20000000 */
   NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
 #else  /* VECT_TAB_FLASH  */
   /* Set the Vector Table base location at 0x08000000 */
   NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
 #endif
 /* enabling interrupt */
   NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn;
   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
   NVIC_Init(&NVIC_InitStructure);
//配置系统时钟,使能各外设时钟
void RCC_Configuration(void)
 SystemInit();
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA
                           |RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC
                           |RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE
         |RCC_APB2Periph_ADC1  | RCC_APB2Periph_AFIO
                           |RCC_APB2Periph_SPI1, ENABLE );
  // RCC_APB2PeriphClockCmd(RCC_APB2Periph_ALL ,ENABLE );
     RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4
                           |RCC_APB1Periph_USART3|RCC_APB1Periph_TIM2
                           , ENABLE );
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
//配置所有外设
void Init_All_Periph(void)
 RCC_Configuration();
 GPIO_Configuration();
 NVIC_Configuration();
// USART1_Configuration();
int main(void)
 Init_All_Periph();
 /* CAN transmit at 100Kb/s and receive by polling in loopback mode*/
   TestRx = CAN_Polling();
   if (TestRx == FAILED)
     /* Turn on led connected to PE.02 pin (LD2) */
   else
     /* Turn on led connected to PD.02 pin (LD2) */
     GPIO_ResetBits(GPIOE, GPIO_Pin_2);
   /* CAN transmit at 500Kb/s and receive by interrupt in loopback mode*/
   TestRx = CAN_Interrupt();
      /* Turn on led connected to PE.04 pin (LD4) */
   else
     GPIO_ResetBits(GPIOE, GPIO_Pin_4);
  while(1)
* Function Name  : CAN_Polling
* Description    : Configures the CAN and transmit and receive by polling
* Input          : None
* Output         : None
* Return         : PASSED if the reception is well done, FAILED in other case
  CAN_InitTypeDef        CAN_InitStructure;
  CAN_FilterInitTypeDef  CAN_FilterInitStructure;
  CanTxMsg TxMessage;
  CanRxMsg RxMessage;
  u32 i = 0;
  u8 TransmitMailbox;
  /* CAN register init */
  CAN_DeInit(CAN1);
  CAN_StructInit(&CAN_InitStructure);
  /* CAN cell init */
  CAN_InitStructure.CAN_TTCM=DISABLE;
  CAN_InitStructure.CAN_ABOM=DISABLE;
  CAN_InitStructure.CAN_AWUM=DISABLE;
  CAN_InitStructure.CAN_NART=DISABLE;
  CAN_InitStructure.CAN_RFLM=DISABLE;
  CAN_InitStructure.CAN_TXFP=DISABLE;
  CAN_InitStructure.CAN_Mode=CAN_Mode_LoopBack;
  CAN_InitStructure.CAN_SJW=CAN_SJW_1tq;
  CAN_InitStructure.CAN_BS1=CAN_BS1_8tq;
  CAN_InitStructure.CAN_BS2=CAN_BS2_7tq;
  CAN_InitStructure.CAN_Prescaler=5;
  CAN_Init(CAN1,&CAN_InitStructure);
  /* CAN filter init */
  CAN_FilterInitStructure.CAN_FilterNumber=0;
  CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;
  CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;
  CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000;
  CAN_FilterInitStructure.CAN_FilterIdLow=0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment=0;
  CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
  CAN_FilterInit(&CAN_FilterInitStructure);
  /* transmit */
  TxMessage.StdId=0x11;
  TxMessage.RTR=CAN_RTR_DATA;
  TxMessage.IDE=CAN_ID_STD;
  TxMessage.DLC=2;
  TxMessage.Data[0]=0xCA;
  TxMessage.Data[1]=0xFE;
  TransmitMailbox=CAN_Transmit(CAN1,&TxMessage);
  i = 0;
  while((CAN_TransmitStatus(CAN1,TransmitMailbox) != CANTXOK) && (i != 0xFF))
    i++;
  i = 0;
  while((CAN_MessagePending(CAN1,CAN_FIFO0) < 1) && (i != 0xFF))
    i++;
  /* receive */
  RxMessage.StdId=0x00;
  RxMessage.IDE=CAN_ID_STD;
  RxMessage.DLC=0;
  RxMessage.Data[0]=0x00;
  RxMessage.Data[1]=0x00;
  CAN_Receive(CAN1,CAN_FIFO0, &RxMessage);
  if (RxMessage.StdId!=0x11) return FAILED;
  if (RxMessage.IDE!=CAN_ID_STD) return FAILED;
  if (RxMessage.DLC!=2) return FAILED;
  if ((RxMessage.Data[0]<<8|RxMessage.Data[1])!=0xCAFE) return FAILED;
  return PASSED; /* Test Passed */
* Function Name  : CAN_Interrupt
* Description    : Configures the CAN and transmit and receive by interruption
* Input          : None
* Output         : None
  CanTxMsg TxMessage;
  u32 i = 0;
  CAN_DeInit(CAN1);
  /* CAN cell init */
  CAN_InitStructure.CAN_Prescaler=1;
  CAN_FilterInitStructure.CAN_FilterNumber=1;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment=CAN_FIFO0;
  /* CAN FIFO0 message pending interrupt enable */
  CAN_ITConfig(CAN1,CAN_IT_FMP0, ENABLE);
  /* transmit 1 message */
  TxMessage.StdId=0x00;
  TxMessage.ExtId=0x1234;
  TxMessage.IDE=CAN_ID_EXT;
  TxMessage.DLC=2;
  TxMessage.Data[0]=0xDE;
  TxMessage.Data[1]=0xCA;
  /* initialize the value that will be returned */
  ret = 0xFF;
  /* receive message with interrupt handling */
  i=0;
  while((ret == 0xFF) && (i < 0xFFF))
    i++;
  if (i == 0xFFF)
    ret=0;
  /* disable interrupt handling */
  CAN_ITConfig(CAN1,CAN_IT_FMP0, DISABLE);
  return (TestStatus)ret;
* Function Name  : USB_LP_CAN_RX0_IRQHandler
* Description    : This function handles USB Low Priority or CAN RX0 interrupts
*                  requests.
* Input          : None
* Output         : None
* Return         : None
void USB_LP_CAN1_RX0_IRQHandler(void)
  CanRxMsg RxMessage;
  RxMessage.ExtId=0x00;
  RxMessage.IDE=0;
  RxMessage.DLC=0;
  RxMessage.FMI=0;
  if((RxMessage.ExtId==0x1234) && (RxMessage.IDE==CAN_ID_EXT)
     && (RxMessage.DLC==2) && ((RxMessage.Data[1]|RxMessage.Data[0]<<8)==0xDECA))
             //设置测试点,观察允许状态
               GPIO_ResetBits(GPIOE,GPIO_Pin_5);
        delay_nms(1000);   // LED1闪烁一次,发送一个字符
        GPIO_SetBits(GPIOE,GPIO_Pin_5);
        delay_nms(1000);
    ret = 1;
  else
    ret = 0;
2012-05-06 21:21:42     打赏
87楼
目前关于中断发送的程序,有问题,希望大侠指点一二,具体见http://forum.eepw.com.cn/thread/213530/1
2012-05-07 21:46:26     打赏
88楼
回环通信的演示比较简单,通过LED来指示CAN的工作是正常的,就不上传图片和视频了。
2012-05-10 13:07:30     打赏
89楼
       搞了小两个周的CAN通信,调试过程相当困苦,到了一种崩溃的状态(有天晚上调试,自己累的都睡着了,半夜3点才醒了,感觉自己是不是要挂了,O(∩_∩)O哈哈~),四处求教,后来自己详细阅读数据手册感觉求人不如求自己,自己深入的学习下吧。付出总有回报,在昨晚凌晨2点终于调试通过了,实现双机的中断通信模式,目前是单工的通信方式,下一步进行全双工的通信方式。
       下面简单谈谈这次调试CAN的一些经验和建议吧,等有时间在详细谈谈。
        首先,在进入CAN的调试实验之前要阅读下相关的CAN的资料,当然不局限于STM32的数据手册,这样是为了便于从基础掌握CAN的通信协议及工作流程。
        其次,详细的阅读STM32数据手册关于CAN的那一节,重点理解各个寄存器的配置,及各个数据位代表的含义;理解并掌握CAN的初始化配置,发送和接受配置以及过滤器的配置;掌握CAN的波特率的设置;掌握CAN中断服务程序的编写;掌握数据发送或接收状态下,各个寄存器内容的变换情况,最好利用JLINK单步调试以便观察。
        再次,认真学习CAN的硬件电路配置情况,虽然咱们使用了开发板,但是为了能够让自己对CAN的认识达到更高一层,还是有必要进行系统的学习。个人认为,在第二步中已经较好的掌握了STM32的CAN控制器的话,可以着装看看CAN的总线收发器也就是驱动器,不要认为电路简单就忽略这部分的学习。要了解VP230(CAN驱动器)的硬件配置,包括各个引脚的功能,尤其是要注意Rs引脚的配置(本次DIY,关于这个问题,我想提个建议就是R51这个电阻不要焊接,我最初调试失败的原因估计十之八九是Rs引脚配置问题),工作在高速或者斜率模式。
        最后,关于程序调试,当然要先从自发自收的测试模式开始,在能够完成自发自收后,然后进入双机通信,需要注意的是:双机通信测试时不能单独测试发送或者接收程序,只有当发送和接收程序都是正确且硬件上无误才能实现双机通信,任何一点错误都能造成通信的失败。可能各位DIY友由于硬件设备的条件有限,不可能具有示波器或者CAN检测仪。我建议关于这个问题,可以在程序的调试过程中加入很多检测程序(我这里用的是在关键代码部分加入LED闪烁语句,以便判断当然CAN的工作状态)。
        暂时先更新这些,有时间继续谈谈个人看法,欢迎批评指正。
2012-05-11 13:07:58     打赏
90楼
新买的JLINK仿真器,花了90元,心疼啊
