电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Storing Battery Fuel Gauge Parameters in
Storing Battery Fuel Gauge Parameters in DS2780
2012-04-03 23:26:51     打赏
关键词: DS2780, Fuel Gauge, Standalone Fuel Gauge, Standalone, Stand Alone, Li+, LiION, Lithium Ion
Abstract: The DS2780 allows the user to customize the stand-alone battery fuel gauge to the exact requirements of the application and the cell being used. The parameters required are typically known in units such as mA, V, mAhrs, and mΩ. The DS2780 requires that the parameters are stored in units such as uV, uVhrs and mhos. This application note describes the calculations involved in converting the typical units into units that are stored in the device.
 Storing Battery Fuel Gauge Parameters in DS2780.pdf
关键词: Storing     Battery     Gauge     Par
