Avoid Design Misinterpretations that Put System Operation in Jeopardy
关键词: noise, inexperienced, clean power, ground planes, impedance DC, level matching, power supply, decoupling capacitors, analog to digital converters, ADC, DAC, signal processing, board layout, bounce, radio resonance, antenna, wavelength, parts misuse
Abstract: Humans are unusual creatures because sometimes partial knowledge, ego, and misplaced confidence are more dangerous than no knowledge of a subject. With electronic design, misinterpretations and misunderstandings can lead to circuits that fail to function as expected. To an inexperienced designer, some circuits look like they should work. Meanwhile, the experienced engineer cringes, wondering how someone can get themselves in such a fix. This application note presents three case studies that illustrate how some simple analysis and a proper understanding of the laws of physics can educate designers to avoid similar issues in future designs.
Avoid Design Misinterpretations that Put System Operation in Jeopardy.pdf
共1条
共1条
【有奖活动】分享技术经验,兑换京东卡 | |
话不多说,快进群! | |
请大声喊出:我要开发板! | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
打赏了!打赏了!打赏了! |
