电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Analog-Signal Data Acquisition in Indust
Analog-Signal Data Acquisition in Industrial Automation Systems
2012-04-12 18:18:37     打赏
关键词: 4-20mA, 0-10V, +/-10V, 0-5V, +/-5V, multiranging adc, analog to digital, analog digital, converters, programmable logic controllers, plc, overranging, fault
Abstract: Industrial control systems continue to employ standard analog signals for transmitting data between the process and the control equipment. Robust, 4-to-20mA current-loop signals that are easily transmitted over several thousand feet, ±5 and ±10V signals are also very common in industrial systems.
 Analog-Signal Data Acquisition in Industrial Automation Systems.pdf
关键词: Analog-Signal     Acquisition
