电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Calibration-Multiplexers Ease System Cal
Calibration-Multiplexers Ease System Calibration
2012-04-14 19:29:41     打赏
关键词: calibration, multiplexers, switch, mux, multiplexer, data-acquisition, IC switches, CMOS
Abstract: IC switches and multiplexers are proliferating, thanks to near-continual progress in lowering the supply voltage, incorporating fault-protected inputs, clamping the output voltage, and reducing the switch resistances. The latest of these advances is the inclusion of precision resistors to allow two-point calibration of gain and offset in precision data-acquisition systems.
 Calibration-Multiplexers Ease System Calibration.pdf
关键词: Calibration-Multiplexers
