The CC2530-CC2591EM Reference Design contains schematics and layout files for the CC2530-CC2591EM evaluation module used in the CC2530-CC2591EMK Evaluation Module Kit.
The reference design demonstrates how to integrate CC2530/CC2531 and CC2591, and shows good techniques for decoupling and RF layout. For optimum RF performance, these parts should be copied accurately. This is a 4-layer reference design with both an SMA antenna connector for RF output matched to 50 ohm and an inverted-F PCB antenna.
文档:swra308a copy.pdf
链接:http://www.ti.com.cn/tool/cn/CC2530-CC2591EM-RD
