学习了,楼主速度真快呀~~
13、关于LCD时钟只显示一行的讨论(已解决)
问题就是,LCD的字符是常量的时候,显示正常,但是如果字符数据时变量,第二行就没法显示,
这个是常量的 这个是变量的
顶层文件:
module lcd_timer(clk,rst_n,key_in,ledout,lcd_en,lcd_rs,lcd_rw,lcd_data);
input clk;
input rst_n;
input [5:0] key_in;
output ledout;
output lcd_en;
output lcd_rs;
output lcd_rw;
output [7:0] lcd_data;
wire clk_en;
Div_50M CLK_DIV
.clk(clk),
.rst(rst_n),
.clk_out(clk_en)
wire [3:0] S_H;
wire [3:0] S_L;
wire SecCout;
counter60 Sec
.en(clk_en),
.clk(clk),
.rst(rst_n),
.key1(key_in[0]),
.key2(key_in[1]),
.cout(SecCout),
.HighOut(S_H),
.LowOut(S_L)
wire [3:0] M_H;
wire [3:0] M_L;
wire MinCout;
counter60 Min
.en(SecCout),
.clk(clk),
.rst(rst_n),
.key1(key_in[2]),
.key2(key_in[3]),
.cout(MinCout),
.HighOut(M_H),
.LowOut(M_L)
wire [3:0] H_H;
wire [3:0] H_L;
counter24 Hour
.en(MinCout),
.clk(clk),
.rst(rst_n),
.key1(key_in[4]),
.key2(key_in[5]),
.cout(ledout),
.HighOut(H_H),
.LowOut(H_L)
lcd1602_driver DISP
.clk(clk),
.rst_n(rst_n),
.lcd_en(lcd_en), // lcd enable
.lcd_rs(lcd_rs), // record,statement
.lcd_rw(lcd_rw),
.lcd_data(lcd_data),
.disp_1th(S_L),
.disp_2th(S_H),
.disp_3th(M_L),
.disp_4th(M_H),
.disp_5th(H_L),
.disp_6th(H_H)
endmodule
50分频
fc = 50MHz 50*10^6
fo = fc*K/(2^32)
K = fo*(2^32)/fc
= fo*(2^32)/(50*10^6)
module Div_50M(clk,rst,clk_out);
input clk; //50MHz
input rst; //clock reset
output reg clk_out;
reg [31:0] cnt;
always@(posedge clk or negedge rst)
begin
if(!rst)
cnt <= 32'd0;
else
cnt <= cnt + 32'd91;
end
begin
if(!rst)
clk_out <= 1'b0;
else
begin
if(cnt < 32'h7FFF_FFFF)
clk_out <= 1'b0;
else
clk_out <= 1'b1;
end
end
endmodule
60计数器
module counter60(en,clk,rst,key1,key2,cout,HighOut,LowOut);
input en,clk,rst;
input key1,key2;
//input mode;
output reg cout;
output [3:0] HighOut;
output [3:0] LowOut;
reg [3:0] HighOut_r;
reg [3:0] LowOut_r;
reg[17:0] cnt;
// reg[3:0] cnt;
always @(posedge clk or negedge rst)
begin
if (!rst)
cnt <= 18'd0;
else
cnt <= cnt + 1'b1;
end
wire sample_pulse = cnt == 18'h3ffff;
reg add1,add2,cnt_en;
begin
if (!rst)
begin
add1 <= 1'b1;
add2 <= 1'b1;
end
else
begin
cnt_en <= en;
if(sample_pulse)
begin
add1 <= key1;
add2 <= key2;
end
end
end
reg add1_r,add2_r,cnt_en_r;
always @(posedge clk ) begin
add1_r <= add1;
add2_r <= add2;
cnt_en_r <= cnt_en;
end
wire add1_ctrl = add1_r & (!add1);
wire add2_ctrl = add2_r & (!add2);
wire cnt_ctrl = (!cnt_en_r) & cnt_en;
always @(posedge clk or negedge rst) begin
if(!rst)
begin
HighOut_r <= 4'b0;
LowOut_r <= 4'b0;
end
else if(add1_ctrl)
begin
HighOut_r <= HighOut_r + 1'b1;
if(HighOut_r >= 4'b0101 ) HighOut_r <= 4'b0;
end
else if(add2_ctrl)
begin
LowOut_r <= LowOut_r + 1'b1;
if(LowOut_r >= 4'b1001 ) LowOut_r <= 4'b0;
end
else if(cnt_ctrl)
begin
if((HighOut_r>=4'b0101)&&(LowOut_r>=4'b1001))
begin
HighOut_r <= 4'b0;
LowOut_r <= 4'b0;
cout = 1;
end
else
begin
cout = 0;
if(LowOut_r >= 4'b1001)
begin
LowOut_r <= 4'b0;
end
end
end
end
assign HighOut = HighOut_r;
assign LowOut = LowOut_r;
endmodule
24计数器
module counter24(en,clk,rst,key1,key2,cout,HighOut,LowOut);
input en,clk,rst;
input key1,key2;
output reg cout;
reg [3:0] LowOut_r;
reg[4:0] counter;
reg[17:0] cnt;
begin
if (!rst)
cnt <= 18'd0;
else
cnt <= cnt + 1'b1;
end
begin
if (!rst)
begin
add1 <= 1'b1;
add2 <= 1'b1;
end
else
begin
cnt_en <= en;
if(sample_pulse)
begin
add1 <= key1;
add2 <= key2;
end
end
end
add1_r <= add1;
add2_r <= add2;
cnt_en_r <= cnt_en;
end
if(!rst)
counter <= 5'b0;
else if(add1_ctrl)
begin
counter <= counter + 1'b1;
if(counter == 5'd23)
counter <= 5'b0;
end
else if(add2_ctrl)
begin
counter <= counter - 1'b1;
if(counter == 5'b0)
counter <= 5'd23;
end
else if(cnt_ctrl)
begin
counter <= 5'b0;
cout <= 1;
end
else
begin
cout <= 0;
end
end
always @(posedge clk) begin
HighOut_r <= counter/10;
LowOut_r <= counter%10;
end
endmodule
lcd1602显示
* Module Name : lcd1602_driver
* Engineer : Anmko
* Target Device : EP2C8Q208C8
* Tool versions : Quartus II 12.0
* Create Date : 2012-9-3
* Revision : v1.0
* Description :
module lcd1602_driver
input clk,
input rst_n,
input [3:0]disp_1th,
input [3:0]disp_2th,
input [3:0]disp_3th,
input [3:0]disp_4th,
input [3:0]disp_5th,
input [3:0]disp_6th,
output lcd_en, // lcd enable
output reg lcd_rs, // record,statement
output reg lcd_rw,
output reg [7:0] lcd_data
parameter [127:0] line_rom1 = "Hello,I' Anmko!";
parameter [127:0] line_rom2 = "EEPW---FPGA DIY!";
reg [7:0] Sec_H;
reg [7:0] Sec_L;
reg [7:0] Min_H;
reg [7:0] Min_L;
reg [7:0] Hour_H;
reg [7:0] Hour_L;
reg [15:0] cnt;
always @ (posedge clk or negedge rst_n)
begin
if(!rst_n)
cnt <= 0;
else
cnt <= cnt + 1'b1;
end
assign lcd_en = cnt[15]; //lcd enable,keep same time; >1000ns
wire cmd_flag = (cnt == 16'h7FFF) ? 1'b1 : 1'b0; //when lcd_en is steady,write a cmd
// Gray code : 40 states
parameter IDLE = 8'h00; // IDLE
// lcd init
parameter CLEAR = 8'h01;
parameter SETFUNCTION = 8'h02;
parameter SWITCHMODE = 8'h03;
parameter SETMODE = 8'h04;
parameter SHIFT = 8'h05;
// parameter SETCGRAM = 8'h40;
// parameter SETDDRAM1 = 8'h81;
// parameter SETDDRAM2 = 8'h82;
// display 1th line
parameter ROW1_ADDR = 8'h09;
parameter ROW1_0 = 8'h0A;
parameter ROW1_1 = 8'h0B;
parameter ROW1_2 = 8'h0C;
parameter ROW1_3 = 8'h0D;
parameter ROW1_4 = 8'h0E;
parameter ROW1_5 = 8'h0F;
parameter ROW1_6 = 8'h10;
parameter ROW1_7 = 8'h11;
parameter ROW1_8 = 8'h12;
parameter ROW1_9 = 8'h13;
parameter ROW1_A = 8'h14;
parameter ROW1_B = 8'h15;
parameter ROW1_C = 8'h16;
parameter ROW1_D = 8'h17;
parameter ROW1_E = 8'h18;
parameter ROW1_F = 8'h19;
// display 2th line
parameter ROW2_ADDR = 8'h1A;
parameter ROW2_0 = 8'h1B;
parameter ROW2_1 = 8'h1C;
parameter ROW2_2 = 8'h1D;
parameter ROW2_3 = 8'h1E;
parameter ROW2_4 = 8'h1F;
parameter ROW2_5 = 8'h20;
parameter ROW2_6 = 8'h21;
parameter ROW2_7 = 8'h22;
parameter ROW2_8 = 8'h23;
parameter ROW2_9 = 8'h24;
parameter ROW2_A = 8'h25;
parameter ROW2_B = 8'h26;
parameter ROW2_C = 8'h27;
parameter ROW2_D = 8'h28;
parameter ROW2_E = 8'h29;
parameter ROW2_F = 8'h2A;
always @ (cmd_flag )
begin
Sec_L = disp_1th;
Sec_L = Sec_L+8'd48;
Sec_H = disp_2th;
Sec_H = Sec_H+8'd48;
Min_L = disp_3th;
Min_L = Min_L+8'd48;
Min_H = disp_4th;
Min_H = Min_H+8'd48;
Hour_L = disp_5th;
Hour_L = Hour_L+8'd48;
Hour_H = disp_6th;
Hour_H = Hour_H+8'd48;
end
reg [7:0] state;
// FSM: ״̬��
begin
if(!rst_n)
begin
lcd_rs <= 0;
lcd_data <= 8'hXX;
end
else if(cmd_flag)
begin
// write statement
case(state)
IDLE :begin
lcd_rs <= 0; lcd_rw <= 0;
lcd_data <= 8'hxx;
state <= CLEAR;
end
//lcd init
CLEAR :begin
lcd_data <= 8'b0000_0001;
state <= SETFUNCTION;
end
SETFUNCTION :begin
lcd_rs <= 0; lcd_rw <= 0; //3C
lcd_data <= 8'b0011_1100;
state <= SWITCHMODE;
end
SWITCHMODE :begin
lcd_rs <= 0; lcd_rw <= 0; //08
lcd_data <= 8'b0000_1000;
state <= SETMODE;
end
SETMODE :begin
lcd_rs <= 0; lcd_rw <= 0; //06
lcd_data <= 8'b0000_0110;
state <= SHIFT;
end
SHIFT :begin
lcd_rs <= 0; lcd_rw <= 0; //0c
lcd_data <= 8'b0000_1100;
state <= ROW1_ADDR;
end
ROW1_ADDR :begin
lcd_data <= 8'b1000_0000;
state <= ROW1_0;
end
ROW1_0 :begin
lcd_rs <= 1; lcd_rw <= 0;
lcd_data <= Hour_H[7:0];//line_rom1[127:120];
state <= ROW1_1;
end
ROW1_1 :begin
lcd_data <= Hour_L[7:0];//line_rom1[119:112];
state <= ROW1_2;
end
ROW1_2 :begin
lcd_data <= ":";//line_rom1[111:104];
state <= ROW1_3;
end
ROW1_3 :begin
lcd_data <= Min_H[7:0];//line_rom1[103:96];
state <= ROW1_4;
end
ROW1_4 :begin
lcd_data <= Min_L[7:0];//line_rom1[95:88];
state <= ROW1_5;
end
ROW1_5 :begin
lcd_data <= ":";//line_rom1[87:80];
state <= ROW1_6;
end
ROW1_6 :begin
lcd_data <= Sec_H[7:0];//line_rom1[79:72];
state <= ROW1_7;
end
ROW1_7 :begin
lcd_data <= Sec_L[7:0];//line_rom1[71:64];
state <= ROW1_8;
end
ROW1_8 :begin
lcd_data <= line_rom1[63:56];
state <= ROW1_9;
end
ROW1_9 :begin
lcd_data <= line_rom1[55:48];
state <= ROW1_A;
end
ROW1_A :begin
lcd_data <= line_rom1[47:40];
state <= ROW1_B;
end
ROW1_B :begin
lcd_data <= line_rom1[39:32];
state <= ROW1_C;
end
ROW1_C :begin
lcd_data <= line_rom1[31:24];
state <= ROW1_D;
end
ROW1_D :begin
lcd_data <= line_rom1[23:16];
state <= ROW1_E;
end
ROW1_E :begin
lcd_data <= line_rom1[15:8];
state <= ROW1_F;
end
ROW1_F :begin
lcd_data <= line_rom1[7:0];
state <= ROW2_ADDR;
end
ROW2_ADDR :begin
lcd_data <= 8'b1100_0000;
state <= ROW2_0;
end
ROW2_0 :begin
lcd_data <= line_rom2[127:120];
state <= ROW2_1;
end
ROW2_1 :begin
lcd_data <= line_rom2[119:112];
state <= ROW2_2;
end
ROW2_2 :begin
lcd_data <= line_rom2[111:104];
state <= ROW2_3;
end
ROW2_3 :begin
lcd_data <= Sec_L[7:0];//line_rom2[103:96];
state <= ROW2_4;
end
ROW2_4 :begin
lcd_data <= line_rom2[95:88];
state <= ROW2_5;
end
ROW2_5 :begin
lcd_data <= line_rom2[87:80];
state <= ROW2_6;
end
ROW2_6 :begin
lcd_data <= line_rom2[79:72];
state <= ROW2_7;
end
ROW2_7 :begin
lcd_data <= line_rom2[71:64];
state <= ROW2_8;
end
ROW2_8 :begin
lcd_data <= line_rom2[63:56];
state <= ROW2_9;
end
ROW2_9 :begin
lcd_data <= line_rom2[55:48];
state <= ROW2_A;
end
ROW2_A :begin
lcd_data <= line_rom2[47:40];
state <= ROW2_B;
end
ROW2_B :begin
lcd_data <= line_rom2[39:32];
state <= ROW2_C;
end
ROW2_C :begin
lcd_data <= line_rom2[31:24];
state <= ROW2_D;
end
ROW2_D :begin
lcd_data <= line_rom2[23:16];
state <= ROW2_E;
end
ROW2_E :begin
lcd_data <= line_rom2[15:8];
state <= ROW2_F;
end
ROW2_F :begin
lcd_data <= line_rom2[7:0];
state <= ROW1_ADDR;
end
default : state <= IDLE;
endcase
end
end
endmodule
问题已经解决。把LCD1602驱动改了一下;红色的为更改部分
* Engineer : Anmko
* Revision : v1.0
* Description :
input clk,
input rst_n,
output reg lcd_rw,
reg [127:0] line_rom1 = "A Clock 00:00:00";
reg [127:0] line_rom2 = "EEPW---FPGA DIY!";
reg [15:0] cnt;
begin
if(!rst_n)
cnt <= 0;
else
cnt <= cnt + 1'b1;
end
begin
line_rom1[7:0] <= 48 + disp_1th;
line_rom1[15:8] <= 48 + disp_2th;
line_rom1[31:24] <= 48 + disp_3th;
line_rom1[39:32] <= 48 + disp_4th;
line_rom1[55:48] <= 48 + disp_5th;
line_rom1[63:56] <= 48 + disp_6th;
end
// lcd init
parameter CLEAR = 8'h01; //锟斤拷锟斤拷
// parameter SETCGRAM = 8'h40; //锟斤拷锟斤拷CGRAM
// parameter SETDDRAM1 = 8'h81; //锟斤拷锟斤拷DDRAM
// parameter SETDDRAM2 = 8'h82; //锟斤拷锟斤拷DDRAM
// display 1th line
// display 2th line
reg [7:0] state;
// FSM: 状态锟斤拷
begin
if(!rst_n)
begin
lcd_rs <= 0;
lcd_data <= 8'hXX;
end
else if(cmd_flag)
begin
// write statement
case(state)
IDLE :begin
lcd_data <= 8'hxx;
state <= CLEAR;
end
//lcd init
CLEAR :begin
end
SETFUNCTION :begin
end
SWITCHMODE :begin
state <= SETMODE;
end
SETMODE :begin
state <= SHIFT;
end
SHIFT :begin
state <= ROW1_ADDR;
end
ROW1_ADDR :begin
state <= ROW1_0;
end
ROW1_0 :begin
lcd_data <= line_rom1[127:120];//Hour_H[7:0];//line_rom1[127:120];
state <= ROW1_1;
end
ROW1_1 :begin
lcd_data <= line_rom1[119:112];//Hour_L[7:0];//line_rom1[119:112];
state <= ROW1_2;
end
ROW1_2 :begin
lcd_data <= line_rom1[111:104];//":";//line_rom1[111:104];
state <= ROW1_3;
end
ROW1_3 :begin
lcd_data <= line_rom1[103:96];//Min_H[7:0];//line_rom1[103:96];
state <= ROW1_4;
end
ROW1_4 :begin
lcd_data <= line_rom1[95:88];//Min_L[7:0];//line_rom1[95:88];
state <= ROW1_5;
end
ROW1_5 :begin
lcd_data <= line_rom1[87:80];//":";//line_rom1[87:80];
state <= ROW1_6;
end
ROW1_6 :begin
lcd_data <= line_rom1[79:72];//Sec_H[7:0];//line_rom1[79:72];
state <= ROW1_7;
end
ROW1_7 :begin
lcd_data <= line_rom1[71:64];//Sec_L[7:0];//line_rom1[71:64];
state <= ROW1_8;
end
ROW1_8 :begin
state <= ROW1_9;
end
ROW1_9 :begin
state <= ROW1_A;
end
ROW1_A :begin
state <= ROW1_B;
end
ROW1_B :begin
state <= ROW1_C;
end
ROW1_C :begin
state <= ROW1_D;
end
ROW1_D :begin
state <= ROW1_E;
end
ROW1_E :begin
state <= ROW1_F;
end
ROW1_F :begin
state <= ROW2_ADDR;
end
ROW2_ADDR :begin
state <= ROW2_0;
end
ROW2_0 :begin
state <= ROW2_1;
end
ROW2_1 :begin
state <= ROW2_2;
end
ROW2_2 :begin
state <= ROW2_3;
end
ROW2_3 :begin
lcd_data <= line_rom2[103:96];
state <= ROW2_4;
end
ROW2_4 :begin
state <= ROW2_5;
end
ROW2_5 :begin
state <= ROW2_6;
end
ROW2_6 :begin
state <= ROW2_7;
end
ROW2_7 :begin
state <= ROW2_8;
end
ROW2_8 :begin
state <= ROW2_9;
end
ROW2_9 :begin
state <= ROW2_A;
end
ROW2_A :begin
state <= ROW2_B;
end
ROW2_B :begin
state <= ROW2_C;
end
ROW2_C :begin
state <= ROW2_D;
end
ROW2_D :begin
state <= ROW2_E;
end
ROW2_E :begin
state <= ROW2_F;
end
ROW2_F :begin
state <= ROW1_ADDR;
end
endcase
end
end
endmodule
| 电子价签墨水屏开发被打赏¥35元 | |
