library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY seg2 IS
PORT (
clk : IN std_logic;
rst : IN std_logic;
dataout : OUT std_logic_vector(7 DOWNTO 0); --各段数据输出
en : OUT std_logic_vector(7 DOWNTO 0)); --COM使能输出
END seg2;
ARCHITECTURE arch OF seg2 IS
signal cnt_scan : std_logic_vector(15 downto 0 );
signal data4 : std_logic_vector(3 downto 0);
signal dataout_xhdl1 : std_logic_vector(7 downto 0);
signal en_xhdl : std_logic_vector(7 downto 0);
begin
dataout<=dataout_xhdl1;
en<=en_xhdl;
process(clk,rst)
begin
if(rst='0')then
cnt_scan<="0000000000000000";
elsif(clk'event and clk='1')then
cnt_scan<=cnt_scan+1;
end if;
end process;
process(cnt_scan(15 downto 13))
begin
case cnt_scan(15 downto 13) is
when"000"=> en_xhdl<="11111110";
when"001"=> en_xhdl<="11111101";
when"010"=> en_xhdl<="11111011";
when"011"=> en_xhdl<="11110111";
when"100"=> en_xhdl<="11101111";
when"101"=> en_xhdl<="11011111";
when"110"=> en_xhdl<="10111111";
when"111"=> en_xhdl<="01111111";
when others=> en_xhdl<="11111110";
end case;
end process;
process(en_xhdl)
begin
case en_xhdl is
when "11111110"=> data4<="0000";
when "11111101"=> data4<="0001";
when "11111011"=> data4<="0010";
when "11110111"=> data4<="0011";
when "11101111"=> data4<="0100";
when "11011111"=> data4<="0101";
when "10111111"=> data4<="0110";
when "01111111"=> data4<="0111";
when others => data4<="1000";
end case;
end process;
process(data4)
begin
case data4 is
WHEN "0000" =>
dataout_xhdl1 <= "11000000";
WHEN "0001" =>
dataout_xhdl1 <= "11111001";
WHEN "0010" =>
dataout_xhdl1 <= "10100100";
WHEN "0011" =>
dataout_xhdl1 <= "10110000";
WHEN "0100" =>
dataout_xhdl1 <= "10011001";
WHEN "0101" =>
dataout_xhdl1 <= "10010010";
WHEN "0110" =>
dataout_xhdl1 <= "10000010";
WHEN "0111" =>
dataout_xhdl1 <= "11111000";
WHEN "1000" =>
dataout_xhdl1 <= "10000000";
WHEN "1001" =>
dataout_xhdl1 <= "00011001";
WHEN "1010" =>
dataout_xhdl1 <= "00010001";
WHEN "1011" =>
dataout_xhdl1 <= "11000001";
WHEN "1100" =>
dataout_xhdl1 <= "01100011";
WHEN "1101" =>
dataout_xhdl1 <= "10000101";
WHEN "1110" =>
dataout_xhdl1 <= "01100001";
WHEN "1111" =>
dataout_xhdl1 <= "01110001";
WHEN OTHERS =>
dataout_xhdl1 <= "00000011";
END CASE;
END PROCESS;
end arch;
