--本实验。按下板上的四个key时。数码管显示得到的数据。
library ieee;
use ieee.std_logic_1164.all;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity KEYLED1 is
PORT ( key_data : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
LED7 : OUT STD_LOGIC_VECTOR(7 DOWNTO 0));
end KEYLED1 ;
ARCHITECTURE behav OF KEYLED1 IS
signal led_temp: std_logic_vector(3 downto 0);
BEGIN
PROCESS( key_data )
BEGIN
led_temp<= key_data ;
CASE led_temp IS
WHEN "1110" => LED7 <= "11111110"; -- 1
WHEN "1101" => LED7 <= "11111101"; -- 2
WHEN "1011" => LED7 <= "11111011"; -- 3
WHEN "0111" => LED7 <= "11110111"; -- 4
WHEN OTHERS => LED7 <= "11111111";
--WHEN OTHERS => NULL ;
END CASE ;
END PROCESS ;
END behav;
