--Please maintain this header statement
-- http://www.pyroelectro.com
--if you use this code. Thank You!!!!!
--Created by Chris @ PyroElectro.com
--Necessary Header Files
--640x480
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
--Define The Core Entity
ENTITY vgaout2 IS
PORT(
--Counter/VGA Timing
clk : IN STD_LOGIC;
--VGA Signals/Pins (Outputs)
hsync,
vsync,
red0,
red1,
red2,
green0,
green1,
green2,
blue0,
blue1 : OUT STD_LOGIC);
--Sync Counters
-- row,
-- column : OUT STD_LOGIC_VECTOR(9 DOWNTO 0));
end vgaout2;
--Define The Architecture Of The Entity
ARCHITECTURE behavior of vgaout2 IS
SIGNAL clk25 :STD_LOGIC;
--Sync Signals
SIGNAL h_sync, v_sync : STD_LOGIC;
--Video Enables
SIGNAL video_en,
horizontal_en,
vertical_en : STD_LOGIC;
--Color Signals
SIGNAL red_signal0,red_signal1,red_signal2,
green_signal0,green_signal1,green_signal2,
blue_signal0,blue_signal1 : STD_LOGIC;
--Sync Counters
SIGNAL h_cnt,
v_cnt : STD_LOGIC_VECTOR(9 DOWNTO 0);
BEGIN
video_en <= horizontal_en AND vertical_en;
--Generate 25Mhz Clock
process (clk)
begin
if clk'event and clk='1' then
if (clk25 = '0')then
clk25 <= '1' after 2 ns;
else
clk25 <= '0' after 2 ns;
end if;
end if;
end process;
PROCESS
--variable cnt: integer range 0 to 25175000;
variable cnt: integer range 0 to 25000000;
BEGIN
--WAIT UNTIL(clk'EVENT) AND (clk = '1');
WAIT UNTIL(clk25'EVENT) AND (clk25 = '1');
--IF(cnt = 25175000)THEN
IF(cnt = 25000000)THEN
cnt := 0;
ELSE
cnt := cnt + 1;
END IF;
--Horizontal Sync
--Reset Horizontal Counter
IF (h_cnt = 799) THEN
h_cnt <= "0000000000";
ELSE
h_cnt <= h_cnt + 1;
END IF;
--Generate Horizontal Data
--160 Rows Of Red
IF (v_cnt >= 0) AND (v_cnt <= 159) THEN
red_signal0 <= '1';
red_signal1 <= '1';
red_signal2 <= '1';
green_signal0 <= '0';
green_signal1 <= '0';
green_signal2 <= '0';
blue_signal0 <= '0';
blue_signal1 <= '0';
END IF;
--160 Rows Of Green
IF (v_cnt >= 160) AND (v_cnt <= 319) THEN
red_signal0 <= '0';
red_signal1 <= '0';
red_signal2 <= '0';
green_signal0 <= '1';
green_signal1 <= '1';
green_signal2 <= '1';
END IF;
--160 Rows Of Blue
IF (v_cnt >= 320) AND (v_cnt <= 479) THEN
red_signal0 <= '0';
red_signal1 <= '0';
red_signal2 <= '0';
blue_signal0 <= '1';
blue_signal1 <= '1';
END IF;
--Generate Horizontal Sync
IF (h_cnt <= 755) AND (h_cnt >= 659) THEN
h_sync <= '0';
ELSE
h_sync <= '1';
END IF;
--Vertical Sync
--Reset Vertical Counter
IF (v_cnt >= 524) AND (h_cnt >= 699) THEN
v_cnt <= "0000000000";
ELSIF (h_cnt = 699) THEN
v_cnt <= v_cnt + 1;
END IF;
--Generate Vertical Sync
IF (v_cnt <= 494) AND (v_cnt >= 493) THEN
v_sync <= '0';
ELSE
v_sync <= '1';
END IF;
IF (h_cnt <= 639) THEN
horizontal_en <= '1';
-- column <= h_cnt;
ELSE
horizontal_en <= '0';
END IF;
--Generate Vertical Data
IF (v_cnt <= 479) THEN
vertical_en <= '1';
-- row <= v_cnt;
ELSE
vertical_en <= '0';
END IF;
--Assign Physical Signals To VGA
red0 <= red_signal0 AND video_en;
red1 <= red_signal1 AND video_en;
red2 <= red_signal2 AND video_en;
green0 <= green_signal0 AND video_en;
green1 <= green_signal1 AND video_en;
green2 <= green_signal2 AND video_en;
blue0 <= blue_signal0 AND video_en;
blue1 <= blue_signal1 AND video_en;
hsync <= h_sync;
vsync <= v_sync;
END PROCESS;
END behavior;
