电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » FPGA 实验连载(九、VGA显示颜色条)
2012-10-13 23:54:45     打赏
--Please maintain this header statement
--     http://www.pyroelectro.com
--if you use this code. Thank You!!!!!
--Created by Chris @ PyroElectro.com
 --Necessary Header Files
--640x480
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
 --Define The Core Entity
ENTITY vgaout2 IS
PORT(
  --Counter/VGA Timing
  clk  : IN STD_LOGIC;
  --VGA Signals/Pins (Outputs)
  hsync,
  vsync,
  red0,
  red1,
  red2,
  green0,
  green1,
  green2,
  blue0,
  blue1 : OUT STD_LOGIC);
  --Sync Counters
--  row,
--  column : OUT STD_LOGIC_VECTOR(9 DOWNTO 0));
end vgaout2;
 --Define The Architecture Of The Entity
ARCHITECTURE behavior of vgaout2 IS
SIGNAL clk25 :STD_LOGIC;
   --Sync Signals
SIGNAL  h_sync, v_sync : STD_LOGIC;
   --Video Enables
SIGNAL  video_en,
  horizontal_en,
  vertical_en : STD_LOGIC;
   --Color Signals
SIGNAL red_signal0,red_signal1,red_signal2,
  green_signal0,green_signal1,green_signal2,
  blue_signal0,blue_signal1 : STD_LOGIC;
   --Sync Counters
SIGNAL  h_cnt,
  v_cnt : STD_LOGIC_VECTOR(9 DOWNTO 0);
BEGIN
 video_en <= horizontal_en AND vertical_en;
--Generate 25Mhz Clock
process (clk)
begin
 if clk'event and clk='1' then
   if (clk25 = '0')then
     clk25 <= '1' after 2 ns;
   else
     clk25 <= '0' after 2 ns;
  end if;
 end if;
end process;
PROCESS
--variable cnt: integer range 0 to 25175000;
variable cnt: integer range 0 to 25000000;
BEGIN
 --WAIT UNTIL(clk'EVENT) AND (clk = '1');
 WAIT UNTIL(clk25'EVENT) AND (clk25 = '1');
 --IF(cnt = 25175000)THEN
 IF(cnt = 25000000)THEN
 cnt := 0;
 ELSE
 cnt := cnt  + 1;
 END IF;
 --Horizontal Sync
  --Reset Horizontal Counter
 IF (h_cnt = 799) THEN
  h_cnt <= "0000000000";
 ELSE
  h_cnt <= h_cnt + 1;
 END IF;
  --Generate Horizontal Data
    --160 Rows Of Red
 IF (v_cnt >= 0) AND (v_cnt <= 159) THEN
  red_signal0 <= '1';
  red_signal1 <= '1';
  red_signal2 <= '1';
  green_signal0 <= '0';
  green_signal1 <= '0';
  green_signal2 <= '0';
  blue_signal0 <= '0';
  blue_signal1 <= '0';
 END IF;
    --160 Rows Of Green
 IF (v_cnt >= 160) AND (v_cnt <= 319) THEN
  red_signal0 <= '0';
  red_signal1 <= '0';
  red_signal2 <= '0';
  green_signal0 <= '1';
  green_signal1 <= '1';
  green_signal2 <= '1';
 END IF;
    --160 Rows Of Blue
 IF (v_cnt >= 320) AND (v_cnt <= 479) THEN
  red_signal0 <= '0';
  red_signal1 <= '0';
  red_signal2 <= '0';
  blue_signal0 <= '1';
  blue_signal1 <= '1';
 END IF;
  --Generate Horizontal Sync
 IF (h_cnt <= 755) AND (h_cnt >= 659) THEN
  h_sync <= '0';
 ELSE
  h_sync <= '1';
 END IF;
 --Vertical Sync
  --Reset Vertical Counter
 IF (v_cnt >= 524) AND (h_cnt >= 699) THEN
  v_cnt <= "0000000000";
 ELSIF (h_cnt = 699) THEN
  v_cnt <= v_cnt + 1;
 END IF;
  --Generate Vertical Sync
 IF (v_cnt <= 494) AND (v_cnt >= 493) THEN
  v_sync <= '0';
 ELSE
  v_sync <= '1';
 END IF;
 IF (h_cnt <= 639) THEN
  horizontal_en <= '1';
--  column <= h_cnt;
 ELSE
  horizontal_en <= '0';
 END IF;
  --Generate Vertical Data
 IF (v_cnt <= 479) THEN
  vertical_en <= '1';
--  row <= v_cnt;
 ELSE
  vertical_en <= '0';
 END IF;
 --Assign Physical Signals To VGA
 red0  <= red_signal0 AND video_en;
 red1  <= red_signal1 AND video_en;
 red2  <= red_signal2 AND video_en;
 green0  <= green_signal0 AND video_en;
 green1  <= green_signal1 AND video_en;
 green2  <= green_signal2 AND video_en;
 blue0 <= blue_signal0 AND video_en;
 blue1 <= blue_signal1 AND video_en;
 hsync <= h_sync;
 vsync <= v_sync;
END PROCESS;
END behavior;
关键词: 实验     连载     显示     色条     LOGIC     video     s
2012-10-14 09:28:08     打赏
想要显示实时的图像害得再加一个图像的DA转换芯片!!
