| EPM7128SLC84-15 是俺的芯片 Warning: Macrocell buffer inserted after node "dataout[53]~reg0" Warning: Macrocell buffer inserted after node "dataout[55]~reg0" Warning: Macrocell buffer inserted after node "dataout[56]~reg0" Error: Can't pack LABs Error: Can't place node "jsq.state_bit_0" of type max_mcell Error: Can't place node "outbit" of type max_mcell Error: Can't place node "data[1]" of type max_mcell Error: Can't place node "jsq.state_bit_1" of type max_mcell Error: Can't place node "data[3]" of type max_mcell Error: Can't place node "jsq.state_bit_2" of type max_mcell Error: Can't place node "data[0]" of type max_mcell Error: Can't place node "data[2]" of type max_mcell Error: Can't place node "data[4]" of type max_mcell Error: Can't place node "data[5]" of type max_mcell Error: Can't place node "temp2[3]" of type max_mcell Error: Can't place node "temp2[2]" of type max_mcell Error: Can't place node "temp2[1]" of type max_mcell Error: Can't place node "temp2[0]" of type max_mcell Error: Can't place node "temp1[3]" of type max_mcell Error: Can't place node "temp1[2]" of type max_mcell Error: Can't place node "temp1[1]" of type max_mcell Error: Can't place node "temp1[0]" of type max_mcell Error: Can't place node "dataout[53]~reg0" of type max_mcell Error: Can't place node "dataout[55]~reg0" of type max_mcell Error: Can't place node "dataout[56]~reg0" of type max_mcell Error: Can't place node "Selector4~27" of type max_mcell Error: Can't place node "Selector2~23" of type max_mcell Error: Can't place node "Selector4~35" of type max_mcell Error: Can't place node "Selector2~31" of type max_mcell Error: Can't find fit Error: Quartus II Fitter was unsuccessful. 27 errors, 3 warnings Error: Peak virtual memory: 161 megabytes Error: Processing ended: Thu Mar 22 16:41:34 2012 Error: Elapsed time: 00:00:01 Error: Total CPU time (on all processors): 00:00:01 Error: Quartus II Full Compilation was unsuccessful. 29 errors, 3 warnings |
