电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » 仿真时quartus报的这些错误是啥意思啊
2012-11-08 18:16:01     打赏
  EPM7128SLC84-15 是俺的芯片
Warning: Macrocell buffer inserted after node "dataout[53]~reg0"
Warning: Macrocell buffer inserted after node "dataout[55]~reg0"
Warning: Macrocell buffer inserted after node "dataout[56]~reg0"
Error: Can't pack LABs
Error: Can't place node "jsq.state_bit_0" of type max_mcell
Error: Can't place node "outbit" of type max_mcell
Error: Can't place node "data[1]" of type max_mcell
Error: Can't place node "jsq.state_bit_1" of type max_mcell
Error: Can't place node "data[3]" of type max_mcell
Error: Can't place node "jsq.state_bit_2" of type max_mcell
Error: Can't place node "data[0]" of type max_mcell
Error: Can't place node "data[2]" of type max_mcell
Error: Can't place node "data[4]" of type max_mcell
Error: Can't place node "data[5]" of type max_mcell
Error: Can't place node "temp2[3]" of type max_mcell
Error: Can't place node "temp2[2]" of type max_mcell
Error: Can't place node "temp2[1]" of type max_mcell
Error: Can't place node "temp2[0]" of type max_mcell
Error: Can't place node "temp1[3]" of type max_mcell
Error: Can't place node "temp1[2]" of type max_mcell
Error: Can't place node "temp1[1]" of type max_mcell
Error: Can't place node "temp1[0]" of type max_mcell
Error: Can't place node "dataout[53]~reg0" of type max_mcell
Error: Can't place node "dataout[55]~reg0" of type max_mcell
Error: Can't place node "dataout[56]~reg0" of type max_mcell
Error: Can't place node "Selector4~27" of type max_mcell
Error: Can't place node "Selector2~23" of type max_mcell
Error: Can't place node "Selector4~35" of type max_mcell
Error: Can't place node "Selector2~31" of type max_mcell
Error: Can't find fit
Error: Quartus II Fitter was unsuccessful. 27 errors, 3 warnings
Error: Peak virtual memory: 161 megabytes
Error: Processing ended: Thu Mar 22 16:41:34 2012
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:01
Error: Quartus II Full Compilation was unsuccessful. 29 errors, 3 warnings
关键词: 仿真     quartus     报的     这些     错误     意思     Wa
