交通灯主频:40mhz;红灯、绿灯:50s;黄灯:10s 双管计数
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Uncomment the following lines to use the declarations that are
-- provided for instantiating Xilinx primitive components.
--library UNISIM;
--use UNISIM.VComponents.all;
entity traffic is
Port ( rst : in std_logic;
clk : in std_logic;
ledout : out std_logic_vector(7 downto 0);
ledk : out std_logic_vector(5 downto 0);
ledA : out std_logic_vector(7 downto 0));
end traffic;
architecture Behavioral of traffic is
signal count: std_logic_vector(7 downto 0);
signal countt: std_logic_vector(26 downto 0);
signal countn: std_logic_vector(15 downto 0);
signal ledat: std_logic_vector(3 downto 0);
signal ledmove:std_logic;
type st is(westg,westy,southg,southy);
signal my_st:st;
begin
process(clk,rst)
begin
if rst='0'then
countt<=(others=>'0');
countn<=(others=>'0');
ledmove<='0';
elsif rising_edge(clk) then
if countt=39999999 then
countn<=countn+1;
else
countt<=countt+1;
countn<=countn+1;
end if;
if countn(15)='1' then
ledmove<= not ledmove;
end if;
end if;
end process;
process(clk,rst)
begin
if rst='0' then
count<="01001001";
my_st<=westg;
ledout<=not "00001100";
case my_st is
when westg=>
if count=0 then
count<="00001001";
my_st<=westy;
elsif countt=39999999 then
count<=count-1;
my_st<=westg;
elsif count(3 downto 0)="1111"then
count(3 downto 0)<=count(3 downto 0)-6;
end if;
when westy=>
ledout<=not "00010100";
if count=0 then
count<="01001001";
my_st<=southg;
count<=count-1;
my_st<=westy;
end if;
when southg=>
ledout<=not "00100001";
if count=0 then
count<="00001001";
my_st<=southy;
count<=count-1;
my_st<=southg;
elsif count(3 downto 0)="1111" then
-- end if;
end if;
when southy=>
ledout<=not "00100010";
if count=0 then
count<="01001001";
my_st<=westg;
count<=count-1;
my_st<=southy;
end if;
when others=>
my_st<=southg;
count<="00001000";
end case;
end if;
end process;
process(clk,rst)
begin
if rst='0' then
ledk<="000011";
case ledmove is
when '0' =>
ledk<=not "111101";
ledat<=count(3 downto 0);
when '1'=>
ledk<=not "111110";
ledat<=count(7 downto 4);
when others=>
ledk<="111111";
ledat<=(others=>'0');
end case;
end if;
end process;
process(ledat)
begin
case ledat is
when"0000"=>
ledA<=x"3f";
when"0001"=>
ledA<=x"06";
when"0010"=>
ledA<=x"5B";
when"0011"=>
ledA<=x"4F";
when"0100"=>
ledA<=x"66";
when"0101"=>
ledA<=x"6D";
when"0110"=>
ledA<=x"7D";
when"0111"=>
ledA<=x"07";
when"1000"=>
ledA<=x"7F";
when"1001"=>
ledA<=x"6F";
when others=>
ledA<=x"00";
end case;
end process;
end Behavioral;
后记:低调做人,谦恭沉静
感谢此论坛及诸位前辈及jackwang、jobs等对在下眷顾之谊!
此程序已调试通过,欢迎质疑指正!
