更换新pc,重新安装了Ubuntu12.04,Qt5.1,编译shanbaydict过程,出现错误,这是由于You are missing the OpenGL include files. Install the mesa-common-dev package, ../../Qt5.1.0/5.1.0/gcc_64/include/QtGui/qopengl.h:110:21: fatal error: GL/gl.h: No such file or directory 执行 sudo apt-get install mesa-common-dev 编译出现如下错误提示: /usr/bin/ld: cannot find -lGL 执行下面命令解决: sudo apt-get install libgl1-mesa-dev libglu1-mesa-dev |
共1条
Qt5.1在ubuntu12.04下解决 GL/gl.h: No such file or directory 与 /usr/bin/ld: cannot fi
只看楼主 1楼
关键词: Qt5.1 ubuntu12.04 解决
共1条
