如下是写的一段发脉冲的程序,功能都是可以实现的,只是觉得是不是代码写得不好所以占用的资源较多,比如if判断太多了,希望大大们看看给点建议
module pulse(sclk, over,DATA, DATA_LAST,diff,dire, AbsErr_flag, rest);
input sclk; //10M时钟
input over; //一次数据读取(含校验)结束标志,结束后维持一周期(0.4us)高电平
input [16:0] DATA;
input [16:0] DATA_LAST;
input [6:0] AbsErr_flag;
input rest;
output diff;
output dire;
wire diff;
wire sclk;
reg dire;
reg [23:0] difcount;
reg exclude_flag;
assign diff = ((difcount)&&(~over))?sclk:1'b0;
//脉冲输出,输出difcount个sclk(脉冲)
always @(posedge over or negedge sclk or negedge rest)//(over|sclk))
begin
if(rest == 1'b0)
begin
difcount = 24'd0;
end
else
begin
if(over) //上升沿只一次
begin
if((AbsErr_flag[6:3] == 0)&&exclude_flag)
begin
if(DATA > DATA_LAST)
begin
if((~(DATA_LAST[16]|DATA_LAST[15]))&(DATA[16]&DATA[15]))
begin
dire =1'b0;
difcount = 24'h20000-DATA+DATA_LAST;
end
else
begin
dire = 1'b1;
difcount = DATA-DATA_LAST;
end
end
else
begin
if((~(DATA[16]|DATA[15]))&(DATA_LAST[16]&DATA_LAST[15]))
begin
dire =1'b1;
difcount = 24'h20000-DATA_LAST+DATA;
end
else
begin
dire = 1'b0;
difcount = DATA_LAST-DATA;
end
end
end
end
else
begin
difcount <= (difcount)?(difcount-1'b1):0; //difcount自减至0
end
end
end
always @(negedge over or negedge rest)
begin
if(rest == 1'b0)
begin
exclude_flag = 0;
end
else
begin
exclude_flag = 1;
end
end
endmodule
这段代码加到主工程里多占了200多的逻辑单元,但是拿出来建工程编译后看好像没那么多。另外附上warnings:
Warning (10240): Verilog HDL Always Construct warning at pulse.v(23): inferring latch(es) for variable "dire", which holds its previous value in one or more paths through the always construct
Warning: Node "pulse:inst|dire" is a latch
Info: Assuming node "rest" is a latch enable. Will not compute fmax for this pin.
Info: Detected gated clock "pulse:inst|always0~1" as buffer
Info: Detected ripple clock "pulse:inst|exclude_flag" as buffer
Info: Detected gated clock "pulse:inst|always0~0" as buffer
Info: Detected ripple clock "pulse:inst|difcount[23]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[22]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[21]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[20]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[19]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[18]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[17]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[16]" as buffer
Info: Detected gated clock "pulse:inst|WideOr0~3" as buffer
Info: Detected ripple clock "pulse:inst|difcount[15]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[14]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[13]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[12]" as buffer
Info: Detected gated clock "pulse:inst|WideOr0~2" as buffer
Info: Detected ripple clock "pulse:inst|difcount[11]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[10]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[9]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[8]" as buffer
Info: Detected gated clock "pulse:inst|WideOr0~1" as buffer
Info: Detected ripple clock "pulse:inst|difcount[7]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[6]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[5]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[4]" as buffer
Info: Detected gated clock "pulse:inst|WideOr0~0" as buffer
Info: Detected ripple clock "pulse:inst|difcount[3]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[2]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[1]" as buffer
Info: Detected gated clock "pulse:inst|WideOr0~6" as buffer
Info: Detected gated clock "pulse:inst|WideOr0~5" as buffer
Info: Detected ripple clock "pulse:inst|difcount[0]" as buffer
Info: Detected ripple clock "send:inst12|AbsErr_flag[3]" as buffer
Info: Detected ripple clock "send:inst12|AbsErr_flag[4]" as buffer
Info: Detected ripple clock "send:inst12|AbsErr_flag[5]" as buffer
Info: Detected ripple clock "send:inst12|AbsErr_flag[6]" as buffer
Info: Detected ripple clock "send:inst12|over" as buffer
Info: Detected gated clock "pulse:inst|dire~3" as buffer
Info: Detected gated clock "pulse:inst|diff" as buffer
Warning: Circuit may not operate. Detected 201 non-operational path(s) clocked by clock "sclk" with clock skew larger than data delay. See Compilation Report for details.
