电子产品世界 » 论坛首页 » 企业专区 » Renesas » R8C开发板学习笔记
共15条 2/2 1 2 跳转至
2014-02-28 15:38:48     打赏
11楼
5、R8C34W中断向量定义错误提示,如“Interrupt number "22" of "vector" has multiple definition.
解决方法:出现的原因是对中断号为22的中断向量重复定义,在用户程序定义该中断函数,如:
// timer RA (software int 22)
#pragma interrupt _timer_ra(vect=22)
void  timer_ra(void);
void  timer_ra(void){
//具体应用程序
但是忽略了HEW自动生成文件intprg.c包含对中断向量的定义,应该把intprg.c文件里对中断向量22的定义部分注释掉或删除。
2014-02-28 15:40:44     打赏
12楼
学习了楼主的帖子,谢谢分享。
2014-03-04 15:48:32     打赏
13楼
R8C&UART常见FAQ.docFAQS for E8A.doc
Uart1通信例程
功能描述:用UART1PC端接收字符,并把字符返给PC端。
模式:9600-8- even-1
程序简介:
void main(void)
clk_set();      //设置时钟为无分频外部晶振
port_cfg();     //设置I/OP0_1/TXD1为输出端口、P0_2/RXD1为输入端口
uart_intial();  //UART1 初始化设置
rcv_cnt = 0;    //接收字符个数清零
ENABLE_IRQ;     // 允许中断
 *   Function Name: uart_intial()
 * Description:  Set UART1:9600-8-N-1.
 *             Note: None
 *  Parameters: None.
 * Returns: None
 * Ext. References: None
 * Preemptible: No.
 *   Reentrant: No.
void uart_intial(void)
        txd1sel0 = 1;
        txd1sel1 = 0;   //选择P0_1为 TXD1
        rxd1sel0 = 1;
        rxd1sel1 = 0;   //选择P0_2为 RXD1
        clk1sel0 = 1;
        clk1sel1 = 0;   //选择P0_3CLK1
        smd2_u1mr = 1;
        smd1_u1mr = 0;
        smd0_u1mr = 1;  //UART mode, transfer data 8 bits long
        ckdir_u1mr = 0; //select Internal clock
        stps_u1mr = 0;  //1 stop bit
        pry_u1mr = 1;   //Even 校验
        prye_u1mr = 1;  //校验使能
        clk0_u1c0 = 0;
        clk1_u1c0 = 0;  //选择f1作为BRG count source
        u1brg = 129;    // bit rate 9600bps
        te_u1c1 = 1;    //UART1 Transmit enable
        re_u1c1 = 1;    //UART1 receive  enable
        u1irs_u1c1 = 0; //选择trans buffer empty(TI=1)作为UART1 transmit中断源
        u1rrm_u1c1 = 0; //continuous receive mode disabled
        ilvl0_s1ric = 1;
        ilvl1_s1ric = 1;
        ilvl2_s1ric = 1;//UART1 receive inttupt priotity7,最高中断优先级
        IPL_0;          // IPL=0,即响应所有优先级别的中断
 *   Function Name: uart1_receive()
 * Description: Reback the data to PC port with UART1.
 *             Note: None
 *  Parameters: None.
 * Returns: None
 * Preemptible: No.
 *   Reentrant: No.
// UART1 receive (software int 20)
#pragma interrupt uart1_receive(vect=20)
void  uart1_receive(void)
    LED2 =!LED2;     //LED2闪烁一次
    ir_s1ric = 0;    //IR清零
    rcv_work = u1rb; // Copy character from UART buffer to rcv_work变量
    if (++rcv_cnt >= 8)
            rcv_cnt = 0;
    uart1receive_buff[rcv_cnt] = (unsigned char) rcv_work;
    while(ti_u1c1 == 0)
            //Wait for transmit buffer is empty
        u1tbl = uart1receive_buff[rcv_cnt];   //把单片机接收到的重新传给PC
运行效果:
并且每接收一个字符,LED2灯闪烁一次。
2014-03-04 16:52:55     打赏
14楼
(补充运行效果图,刚上传的看不到)
2014-03-21 16:10:50     打赏
15楼
timerRA应用实例
实现功能:用定时器timerRA提供3个不同频率信号0.5Hz,1Hz和2Hz,分别用3个指示灯LED1、LED2、LED3以上诉3种不同的频率闪烁。LED1亮灭时间相同,LED2与LED3常态是灭状态,在频率边沿处闪烁一次。
注:用示波器可以更加精确地捕获输出信号的频率
流程图:
程序简介:
int led_shifttime = 0;
int led3_shifttime = 0;
void main(void)
 /* Timer RA initialization sequence */
 /* Low speed on-chip oscillator is used (125kHz) instead of external clocking */
 //ocd2=1; // 选择On-chip oscillator clock作为system clock,因为复位后ocd2为1所以可以省略此句
 /* 设置TRAO为输出端口 */
 toena_traioc = 1;
 /* 设置timerRA 位Timer mode */
 tmod0_tramr = 0;
 tmod1_tramr = 0;
 tmod2_tramr = 0;
 /* 选择片上低速时钟Low speed on-chip oscillator作为timerRA的时钟源 */
 tck0_tramr = 0;
 tck1_tramr = 1;
 tck2_tramr = 0;
 //RA timmer 中断发生间隔为t,则t=(trapre+1)*(pre+1)*1/ F(OCO)
  trapre = 249;
 tra = 249;  //RA timer中断时间间隔为0.5s
 /* 清零timerRA中的标志位 */
 ir_traic = 0;
 /* 设置timerRA中断等级为1级 */
 ilvl1_traic = 1;
 /* 开启timerRA定时器 */
 tstart_tracr = 1;
 /*  允许中断 */
 ENABLE_IRQ;
 /* LED0 LED1 LED2 LED3初始状态都是灭状态 */
 p3 = 0x5A;
pd3 = 0xFF;
 while (1)
      if (led_shifttime == 2)
            led_shifttime = 0; //led_shifttime计数周期为2个RA timer中断间隔,即2*0.5s=1s
            LED1 = !LED1;      //LED1每隔1s变换一次状态
            LED2 = !LED2;
            LED2 = !LED2;      //LED2每隔1s闪烁一次
  else
  if(led3_shifttime == 1)
       led3_shifttime =0; //led3_shifttime计数周期为1个RA timer中断间隔,即0.5s
       LED3 = !LED3;
             LED3 = !LED3;      //LED3闪烁一次,间隔为0.5s
  else
Function Name: timer_ra
Description: Timer RA中断函数.
Parameters:  None
Return Value: None
/* timer RA   (software int 22) */
#pragma interrupt timer_ra(vect=22)
void timer_ra(void)
 led_shifttime++;
 led3_shifttime++;  //每进入一次RA timer中断,间隔为0.5s,两个计数加1
 ir_traic = 0;      //中断标志位IR清零
总结:
定时器timerRA的使用重点,首先设置timerRA的工作模式为timer mode;
第二,选择timerRA的时钟源;
第三,通过设置寄存器trapre和tra来得到发生timerRA中断的时间间隔
每次发生timerRA中断的间隔时间确定后,再在timerRA中断函数中设定相应的动作。相当于以中断间隔作为该动作发生的长度标尺。
共15条 2/2 1 2 跳转至
