电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » LPC1227 LED闪烁实验
LPC1227 LED闪烁实验
2014-09-14 21:05:41     打赏
LPCXpresso-CN-1227这个板子使用的万利的MLINK仿真器,使用IAR编程环境,下载时出现问题,一直不能下载进Flash,弄了几天,无果,遂采用ISP的方式进行下载,但是这样就不能Debug,先只能这样用了。
/* Includes ------------------------------------------------------------------*/ #include "lpc12xx_libcfg.h"
/* Private define ------------------------------------------------------------*/ /* Number of user LEDs */ #define LED_NUM     4 const unsigned long led_mask[] = { 4, 5, 6,7};
/* Private variables ---------------------------------------------------------*/ /* SysTick Counter */ volatile unsigned long SysTickCnt;
/* Private functions ---------------------------------------------------------*/ void SysTick_Handler (void);
void Delay (unsigned long tick);
/**   * @brief     SysTick handler sub-routine (1ms)   * @param  None   * @return   None   */ void SysTick_Handler (void) {   SysTickCnt++; }
/**   * @brief     Delay function   * @param  tick - number milisecond of delay time   * @return  None   */ void Delay (unsigned long tick) {   unsigned long systickcnt;
  systickcnt = SysTickCnt;   while ((SysTickCnt - systickcnt) < tick); }
/**   * @brief      Main program body   * @param   None   * @return    int   */ int main (void) {                       /* Main Program                       */   int num = -1;   IOCON_PIO_CFG_Type PIO_mode;
  SystemInit();                                                       /* 系统时钟初始化 */   SysTick_Config(SystemCoreClock/1000 - 1); /* Generate interrupt each 1 ms   */
  SYS_ConfigAHBCLK(SYS_AHBCLKCTRL_GPIO0, ENABLE);
  IOCON_StructInit(&PIO_mode);   PIO_mode.type = IOCON_PIO_0_4;   IOCON_SetFunc(&PIO_mode);   PIO_mode.type = IOCON_PIO_0_5;   IOCON_SetFunc(&PIO_mode);   PIO_mode.type = IOCON_PIO_0_6;   IOCON_SetFunc(&PIO_mode);     PIO_mode.type = IOCON_PIO_0_7;   IOCON_SetFunc(&PIO_mode);           GPIO_SetDir(LPC_GPIO0, 4, 1);     GPIO_SetDir(LPC_GPIO0, 5, 1);      GPIO_SetDir(LPC_GPIO0, 6, 1);   GPIO_SetDir(LPC_GPIO0, 7, 1);      GPIO_SetLowLevel(LPC_GPIO0, 4, 1);     GPIO_SetLowLevel(LPC_GPIO0, 5, 1);      GPIO_SetLowLevel(LPC_GPIO0, 6, 1);   GPIO_SetLowLevel(LPC_GPIO0, 7, 1);      for (;;)   {                            /* Loop forever                       */     num += 1;     if (num == LED_NUM)     {       num =  0;     }
    GPIO_SetHighLevel(LPC_GPIO0, led_mask[num],1);     Delay(500);                         /* Delay 500ms                        */     GPIO_SetLowLevel(LPC_GPIO0, led_mask[num],1);     Delay(500);                         /* Delay 500ms                        */
