电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » OLED屏(1305控制器)初始化代码
OLED屏(1305控制器)初始化代码
2014-09-16 20:04:50     打赏
void OLED_Init() { unsigned char i;
        RES=0;         for(i=0;i<200;i++)         {                 uDelay(200);         }         RES=1;
        Set_Display_On_Off(0xAE);                // Display Off (0xAE/0xAF)         Set_Display_Clock(0xA0);                // Set Clock as 80 Frames/Sec         Set_Multiplex_Ratio(0x3F);                // 1/64 Duty (0x0F~0x3F)         Set_Display_Offset(0x00);                // Shift Mapping RAM Counter (0x00~0x3F)         Set_Start_Line(0x00);                        // Set Mapping RAM Display Start Line (0x00~0x3F)         Set_Master_Config(0x8E);                // Disable Embedded DC/DC Converter (0x8E/0x8F)         Set_Area_Color(0x05);                        // Set Monochrome & Low Power Save Mode         Set_Addressing_Mode(0x02);                // Set Page Addressing Mode (0x00/0x01/0x02)         Set_Segment_Remap(0xA1);                // Set SEG/Column Mapping (0xA0/0xA1)         Set_Common_Remap(0xC8);                        // Set COM/Row Scan Direction (0xC0/0xC8)         Set_Common_Config(0x12);                // Set Alternative Configuration (0x02/0x12)         Set_LUT(0x3F,0x3F,0x3F,0x3F);                // Define All Banks Pulse Width as 64 Clocks         Set_Contrast_Control(Brightness);        // Set SEG Output Current         Set_Area_Brightness(Brightness);        // Set Brightness for Area Color Banks         Set_Precharge_Period(0x82);                // Set Pre-Charge as 8 Clocks & Discharge as 2 Clocks         Set_VCOMH(0x3C);                        // Set VCOM Deselect Level         Set_Entire_Display(0xA4);                // Disable Entire Display On (0xA4/0xA5)         Set_Inverse_Display(0xA6);                // Disable Inverse Display On (0xA6/0xA7)
        Fill_RAM(0x00);                                // Clear Screen
        Set_Display_On_Off(0xAF);                // Display On (0xAE/0xAF) }
