#include "stm32f10x.h"
#include "stm32_eval.h"
//#include "delay.h"
#include <stdio.h>
#define VREF 3.3
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup EXTI_Config
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
void RCC_Configuration(void)
SystemInit();
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_ResetBits(GPIOD,GPIO_Pin_2);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
void delay_us(u32 n)
u8 j;
while(n--)
for(j=0;j<10;j++);
void delay_ms(u32 n)
while(n--)
delay_us(1000);
void USART_int(long BaudRate)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* PA10 USART1_Rx */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
/* USARTx configured as follow:
- BaudRate = 115200 baud
- Word Length = 8 Bits
- One Stop Bit
- No parity
- Hardware flow control disabled (RTS and CTS signals)
- Receive and transmit enabled
USART_InitStructure.USART_BaudRate = BaudRate;//??????
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
USART_InitStructure.USART_Parity = USART_Parity_No;//????
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
USART_ClockInit(USART1, &USART_ClockInitStructure);
USART_Init(USART1, &USART_InitStructure);
USART_Cmd(USART1, ENABLE);
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
void PWM_Config()
{ uint16_t PrescalerValue = 0;
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
/* TIM2 clock enable */
/* GPIOA enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO , ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
TIM_Cmd(TIM2, ENABLE);
/* Compute the prescaler value */
PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1;
/* Time base configuration */
TIM_TimeBaseStructure.TIM_Period = 0x07FF;
TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;//????????1
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
/* PWM1 Mode configuration: Channel2 */
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_Pulse = 0xFFFF;
TIM_OC2Init(TIM2, &TIM_OCInitStructure);
/* PWM1 Mode configuration: Channel3 */
TIM_OC3Init(TIM2, &TIM_OCInitStructure);
/* PWM1 Mode configuration: Channel4 */
TIM_OC4Init(TIM2, &TIM_OCInitStructure);
TIM_ARRPreloadConfig(TIM2, ENABLE);
void PWM_TEST()
{ unsigned int temp0=0,temp1=0,temp2=0,i=0;
printf("PWM-RGB TEST......\r\n");
for(;i<200;i++)//?
TIM_SetCompare2(TIM2, temp0);
TIM_SetCompare3(TIM2, temp1);
TIM_SetCompare4(TIM2, temp2);
temp0=1600,temp1=900,temp2=100;
delay_ms(500);
for(;i<200;i++)//??
temp0=100,temp1=2400,temp2=240;
delay_ms(500);
for(;i<200;i++)//
temp0=2400,temp1=1600,temp2=3200;
delay_ms(500);
for(;i<200;i++)
temp0=2330,temp1=0,temp2=2000;
delay_ms(500);
for(;i<200;i++)
temp0=100,temp1=40,temp2=1020;
delay_ms(500);
for(;i<200;i++)
temp0=0,temp1=800,temp2=0;
delay_ms(500);
for(;i<200;i++)
temp0=0,temp1=1000,temp2=2400;
delay_ms(500);
/* Private functions ---------------------------------------------------------*/
* @brief Main program.
* @param None
* @retval None
int main(void)
/*!< At this stage the microcontroller clock setting is already configured,
this is done through SystemInit() function which is called from startup
file (startup_stm32f10x_xx.s) before to branch to application main.
To reconfigure the default setting of SystemInit() function, refer to
system_stm32f10x.c file
/* System Clocks Configuration */
RCC_Configuration();
USART_int(115200);
printf(" config done...\r\n");
PWM_Config();
delay_ms(1000);
while(1)
PWM_TEST();
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
#ifdef __GNUC__
/* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
set to 'Yes') calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
* @brief Retargets the C library printf function to the USART.
* @param None
* @retval None
PUTCHAR_PROTOTYPE
/* Place your implementation of fputc here */
/* e.g. write a character to the USART */
USART_SendData(EVAL_COM1, (uint8_t) ch);
/* Loop until the end of transmission */
while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
return ch;
* @retval None
/* Infinite loop */
while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
ADC控制rgb
#include <stdio.h>
#define VREF 3.3
SystemInit();
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
- One Stop Bit
- No parity
u8 j;
while(n--)
for(j=0;j<10;j++);
while(n--)
delay_us(1000);
void PWM_Config()
{uint16_t PrescalerValue = 0;
/* GPIOA enable */
void ADC_CONFIG(){
ADC_InitTypeDef ADC_InitStructure;
#if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL)
/* ADCCLK = PCLK2/2 */
RCC_ADCCLKConfig(RCC_PCLK2_Div2); //??ADC1,????????
#else
/* ADCCLK = PCLK2/4 */
RCC_ADCCLKConfig(RCC_PCLK2_Div4);
#endif
ADC_DeInit(ADC1);
/* Enable ADC1 and GPIOC clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOB, ENABLE);
/* Configure PB0 (ADC Channel14) as analog input -------------------------*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
GPIO_Init(GPIOB, &GPIO_InitStructure);
/* ADC1 configuration ------------------------------------------------------*/
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //ADC????:????
ADC_InitStructure.ADC_ScanConvMode = ENABLE; //AD?????
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //AD??????
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //??????????????
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //ADC?????
ADC_InitStructure.ADC_NbrOfChannel = 1; //?????????ADC?????1
ADC_Init(ADC1, &ADC_InitStructure); //???????????ADC1
/* Enable ADC1 DMA */
ADC_DMACmd(ADC1, ENABLE);
/* Enable ADC1 */
ADC_Cmd(ADC1, ENABLE);
int Get_ADC(){
/* ADC1 regular channel configuration */
ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 1, ADC_SampleTime_55Cycles5); //???????1???,?????55.5
/* Enable ADC1 reset calibration register */
ADC_ResetCalibration(ADC1); //??????
/* Check the end of ADC1 reset calibration register */
while(ADC_GetResetCalibrationStatus(ADC1));
/* Start ADC1 calibration */
ADC_StartCalibration(ADC1); //??ADC??,?????ADC1?????
/* Check the end of ADC1 calibration */
while(ADC_GetCalibrationStatus(ADC1));
/* Start ADC1 Software Conversion */
ADC_SoftwareStartConvCmd(ADC1, ENABLE); //????ADC??
return ADC_GetConversionValue(ADC1);
void PWM_TEST()
float Volt=0.00;
unsigned int temp0,temp1,temp2,ADValue = 0;
while(1)
ADValue = Get_ADC();
Volt = VREF*ADValue/4095;
printf("PWM-RGB & ADC TEST......\r\n\r\n");
printf("The ADC value is:%d\r\n",ADValue);
printf("The Volt is:%f V\r\n",Volt);
if(ADValue>3000)
{ temp0=ADValue/2;temp1=ADValue/2;temp2=ADValue/2-1500;
if(2000<ADValue<=3000)
{ temp0=ADValue/2;temp1=ADValue/2-1000;temp2=ADValue/2;
if(1000<ADValue<=2000)
{ temp0=ADValue/2+1000;temp1=ADValue/2;temp2=ADValue/2;
if(ADValue<=1000)
{ temp0=ADValue+500;temp1=ADValue+1500;temp2=ADValue+1000;
delay_ms(50);
* @param None
* @retval None
int main(void)
USART_int(115200);
ADC_CONFIG();
Get_ADC();
PWM_Config();
delay_ms(200);
while(1)
PWM_TEST();
while (1)
#endif
#ifdef __GNUC__
#else
PUTCHAR_PROTOTYPE
return ch;
while (1)
#endif
串口控制led
#include "stdio.h"
#define buff_size 16;
char rx_buff[],rx_buff_count=0;
RCC_DeInit();
RCC_HSICmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
RCC_HSEConfig(RCC_HSE_OFF);
RCC_LSEConfig(RCC_LSE_OFF);
RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz
RCC_PLLCmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
RCC_PCLK2Config(RCC_HCLK_Div1);
RCC_PCLK1Config(RCC_HCLK_Div2);
RCC_HCLKConfig(RCC_SYSCLK_Div1);
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
while(RCC_GetSYSCLKSource() != 0x08);
void GPIO_INIT()
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
u8 j;
while(n--)
for(j=0;j<10;j++);
while(n--)
delay_us(1000);
{ USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
- One Stop Bit
- No parity
/* Configure four bit for preemption priority */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);
/* Enable the USART1 Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
void USART_SendStr(char *str)
while((*str)!='\0')
{USART_SendData(USART1,*str++);
while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
char strcmp(char *S,char *C,char LEN)
{ char count;
for(count=0;count<LEN;count++)
if(S[count]!=C[count])
{return 0;}
return 1;
void commcmp(char *S,char LEN)
int i,j;
unsigned char flag=0;
if((LEN!=7)&(LEN!=8)&(LEN!=9))
{USART_SendStr("\r\n Erro input!!!\r\n");}
else{
switch(LEN)
case 7:
flag = strcmp(S,"time=50",7);
if(flag==1)
for(i=0;i<=18;i++)
i=0x01;
GPIO_ResetBits(GPIOC,i);
delay_ms(50);
GPIO_SetBits(GPIOC,i);
for(j=1;j<=3;j++)
i<<=1;
delay_ms(50);
i=0x0100;
for(j=1;j<=4;j++)
i>>=1;
delay_ms(50);
break;
case 8:
flag = strcmp(S,"time=100",8);
if(flag==1)
for(i=0;i<=18;i++)
i=0x0010;
for(j=1;j<=4;j++)
i>>=1;
delay_ms(100);
i=0x08;
for(j=1;j<=4;j++)
i<<=1;
delay_ms(100);
break;
case 9:
flag = strcmp(S,"time=1000",9);
if(flag==1)
for(i=0;i<=18;i++)
GPIO_SetBits(GPIOC,0x000000ff);
i=0x00100;
for(j=1;j<=8;j++)
i>>=1;
delay_ms(1000);
break;
void input_ASK()
char j;
commcmp(rx_buff,rx_buff_count);
rx_buff_count=0;
for (j=0;j<rx_buff_count;j++)
{rx_buff[j]='\0';}
USART_SendStr("\n>");
int main(void)
GPIO_INIT();
USART_int(9600);
USART_SendStr("SyStem booting......\r\n");
while(1){}
void USART1_IRQHandler(void)
while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET)
if(USART_ReceiveData(USART1)==0x0d)
{input_ASK();}
else
USART_SendData(USART1,USART_ReceiveData(USART1));
rx_buff[rx_buff_count]= USART_ReceiveData(USART1);
rx_buff_count++;
USART_ClearFlag(USART1, USART_FLAG_RXNE);
IIC上电计数
#include <stdio.h>
#define VREF 3.3
EXTI_InitTypeDef EXTI_InitStructure;
unsigned char i=0;
u8 j;
while(n--)
for(j=0;j<10;j++);
while(n--)
delay_us(1000);
RCC_DeInit();
RCC_HSICmd(ENABLE);
RCC_PLLCmd(ENABLE);
//SystemInit();
GPIO_ResetBits(GPIOD,GPIO_Pin_2);//·äÃùÆ÷
USART_InitStructure.USART_BaudRate = BaudRate;//usart´«Ê䲨±ÈÌØ
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//Ò»Ö¡´«Êä»ò½ÓÊÕ8bit
USART_InitStructure.USART_StopBits = USART_StopBits_1;//ÔÚÖ¡½áβ´«Êä1¸öֹͣλ
USART_InitStructure.USART_Parity = USART_Parity_No;//ÆæÅ¼Ê§ÄÜ
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//Ó²¼þÁ÷¿ØÖÆÊ§ÄÜ
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//½ÓÊÕʹÄÜ£¬·¢ËÍʹÄÜ
USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;//ʱÖÓµÍµçÆ½»î¶¯
USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;//ʼÖÕµÍµçÆ½
USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;//ʱÖÓµÚ¶þ±ßÔµ½øÐÐÊý¾Ý²¶»ñ
USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;//×îºóһλÊý¾ÝµÄʱÖÓ²»´ÓSCLKÊä³ö
USART_ClockInit(USART1, &USART_ClockInitStructure);//ʹÄÜUSART1ʱÖÓ
USART_Init(USART1, &USART_InitStructure);//³õʼ»¯USART1
USART_Cmd(USART1, ENABLE);//ʹÄÜUSART1ÍâÉè
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//ʹÄÜÖжÏ
void Iic1_Init(void)
I2C_InitTypeDef I2C_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C2, ENABLE);
//PB6-I2C2_SCL PB7-I2C2_SDA PB10-I2C2_SCL PB11-I2C2_SDA
/* Configure IO connected to IIC*********************/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;//ÅäÖÃI2Cģʽ
I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;//¸Ã²ÎÊýÖ»ÓÐÔÚI2C¹¤×÷ÔÚ¿ìËÙģʽÏÂÓÐÒâÒå
I2C_InitStructure.I2C_OwnAddress1 = 0xA0;//ÉèÖõÚÒ»¸öÉ豸×ÔÉíµØÖ·
I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;//ʹÄÜÓ¦´ð
I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;//µØÖ·Îª7λ
I2C_InitStructure.I2C_ClockSpeed = 400000;//ʱÖÓËÙÂÊ 400KHZ
I2C_Cmd(I2C2, ENABLE);
I2C_Init(I2C2, &I2C_InitStructure);
I2C_AcknowledgeConfig(I2C2, ENABLE);
void I2C2_WriteByte(unsigned char id,unsigned char write_address,unsigned char byte)
while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY));
I2C_GenerateSTART(I2C2,ENABLE);
while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_MODE_SELECT));
I2C_Send7bitAddress(I2C2,id,I2C_Direction_Transmitter);
while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
I2C_SendData(I2C2, write_address);
while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
I2C_SendData(I2C2, byte);
I2C_GenerateSTOP(I2C2, ENABLE);
do
/* Send START condition */
I2C_GenerateSTART(I2C2, ENABLE);
/* Read I2C2 SR1 register */
/* Send EEPROM address for write */
I2C_Send7bitAddress(I2C2, 0xA0, I2C_Direction_Transmitter);
}while(!(I2C_ReadRegister(I2C2, I2C_Register_SR1) & 0x0002));
/* Clear AF flag */
I2C_ClearFlag(I2C2, I2C_FLAG_AF);
/* STOP condition */
unsigned char I2C2_ReadByte(unsigned char id, unsigned char read_address)
unsigned char temp;
while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY)){}
I2C_Send7bitAddress(I2C2, id, I2C_Direction_Transmitter);
I2C_SendData(I2C2, read_address);
I2C_Send7bitAddress(I2C2, id, I2C_Direction_Receiver);
while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
I2C_AcknowledgeConfig(I2C2, DISABLE);
while(!(I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_RECEIVED)));
temp = I2C_ReceiveData(I2C2);
return temp;
void EXTIkeyS1_Config(void)
/* Enable GPIOA clock */
/* Configure PA.00 pin as input floating */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
/* Enable AFIO clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
/* Connect EXTI0 Line to PA.00 pin */
GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource8);
/* Configure EXTI0 line */
EXTI_InitStructure.EXTI_Line = EXTI_Line8;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure);
/* Enable and set EXTI0 Interrupt to the lowest priority */
NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
void EXTI9_5_IRQHandler(void) //s1
if(EXTI_GetITStatus(EXTI_Line8) != RESET)
i=0;
I2C2_WriteByte(0xA0,0,0);
printf("°´¼üÇå:%d \r\n",i);
EXTI_ClearITPendingBit(EXTI_Line8);
void IIC_TEST()
while(1){
printf("IIC²âÊÔ¿ªÊ¼.....\r\n");
i=I2C2_ReadByte(0xA0,0);
printf("´ÓµØÖ·0x00¶Á³öÊý¾Ý:%d\r\n",i);
delay_ms(1000);
i++;
I2C2_WriteByte(0xA0,0,i);
printf("Ïò0x00дÈëÊý¾Ý:%d\r\n",i);
delay_ms(1000);
printf("ÉÏµç¼ÆÊý:%d\r\n",i);
int main(void)
USART_int(115200);
EXTIkeyS1_Config();
Iic1_Init();
delay_ms(1000);
IIC_TEST();
while (1)
#endif
#ifdef __GNUC__
#else
PUTCHAR_PROTOTYPE
return ch;
while (1)
#endif
时钟滴答
#include
volatile int flag;
#define Set_B20() GPIO_SetBits(GPIOC, GPIO_Pin_12)//上拉关闭pc12
#define Reset_B20() GPIO_ResetBits(GPIOC, GPIO_Pin_12)//下拉打开pc12
#define Read_B20() GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_12)//读pc状态
unsigned char Error_Flag=0;
unsigned char zf=0;
/**************延时函数*******************/
u8 j;
while(n--)
for(j=0;j<10;j++);
while(n--)
delay_us(1000);
void SysTick_Configuration(void)
/* Setup SysTick Timer for 10 msec interrupts */
if (SysTick_Config(48000))
/* Capture error */
while (1);
/* Configure the SysTick handler priority */
NVIC_SetPriority(SysTick_IRQn, 0x0);
RCC_DeInit();//将RCC寄存器重设为缺省值
RCC_HSICmd(ENABLE);//使能内部高速晶振
while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);//HSI晶振返回reset
RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);//选择HSI作为系统时钟
RCC_HSEConfig(RCC_HSE_OFF);//HSE晶振关
RCC_LSEConfig(RCC_LSE_OFF);//LSE晶振关
RCC_PLLCmd(ENABLE);//使能PLL状态
RCC_ADCCLKConfig(RCC_PCLK2_Div4);//ADC时钟=PCLK/4
RCC_PCLK2Config(RCC_HCLK_Div1);//APB2时钟=HCLK
RCC_PCLK1Config(RCC_HCLK_Div2);//APB1时钟=HCLK/2
RCC_HCLKConfig(RCC_SYSCLK_Div1);//AHB时钟=系统时钟
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//选择PLL作为系统时钟
GPIO_ResetBits(GPIOD,GPIO_Pin_2);//关闭蜂鸣器
- One Stop Bit
- No parity
USART_InitStructure.USART_BaudRate = BaudRate;//usart传输波比特
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//一帧传输或接收8bit
USART_InitStructure.USART_StopBits = USART_StopBits_1;//在帧结尾传输1个停止位
USART_InitStructure.USART_Parity = USART_Parity_No;//奇偶失能
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//硬件流控制失能
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//接收使能,发送使能
USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;//时钟低电平活动
USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;//始终低电平
USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;//时钟第二边缘进行数据捕获
USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;//最后一位数据的时钟不从SCLK输出
USART_ClockInit(USART1, &USART_ClockInitStructure);//使能USART1时钟
USART_Init(USART1, &USART_InitStructure);//初始化USART1
USART_Cmd(USART1, ENABLE);//使能USART1外设
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//使能中断
void delay_18b20(u32 nus)//18b20专属延时
u16 i;
while(nus--)
for(i=12;i>0;i--);
void Init18B20(void)//初始化
u8 aa=0;
u8 count =0;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
Set_B20() ;
delay_18b20(1);
Reset_B20();
delay_18b20(480);
Set_B20();
// delay_18b20(500);
delay_18b20(480);
count=0;
aa=Read_B20();
while(!aa && count<100)
aa=Read_B20();
count++;
if(count>=99)
Error_Flag=1;
else
Error_Flag=0;
unsigned char Read18B20(void)//按位读取数据
unsigned char i=0;
unsigned char date=0;
u8 tempp;
for(i=8;i>0;i--)
Reset_B20();//打开pc12
date>>=1;//标识右移一位
delay_18b20(1);
Set_B20(); //关闭pc12
delay_18b20(1);
tempp=Read_B20();//温度读取
if(tempp)
date|=0x80;
delay_18b20(60);
return(date);
void Write18B20(unsigned char date)//读数据
unsigned char i=0;
for (i=8; i>0; i--)
Reset_B20();
delay_18b20(1);
if(date & 0x01)
Set_B20();
else
{ Reset_B20();}
delay_18b20(60);
date>>=1;
Set_B20();
delay_18b20(1);
delay_18b20(15);
float Read_T()//读温度
unsigned char TUp,TDown;
unsigned char fTemp;
u8 TT=0;
float Temp = 0;
Init18B20();
Write18B20(0xcc);
Write18B20(0x44);
Init18B20();
Write18B20(0xcc);
Write18B20(0xbe);
TDown = Read18B20();
TUp = Read18B20();
if(TUp>0x7f)
TDown=~TDown;
TUp=~TUp+1;
TUp/=8;
zf=1;
else
zf=0;
fTemp=TDown&0x0f;
TUp<<=4;
TDown>>=4;
TT=TUp|TDown;
Temp=TT+(float)fTemp/16;
return(Temp);
int main(void)
char ID[8];
int i;
USART_int(115200);
SysTick_Configuration();
delay_ms(1000);
Init18B20();
Write18B20(0x33);
delay_18b20(20);
for(i=0;i<8;i++) //大神说这里要用for语句,不然只会输出printf("event 1 oc......\r\n")这句,不会继续运行
ID[i] = Read18B20();//读取地址
while(1)
if(flag == 300)
printf("At the moment of ID is:") ;
for(i=0;i<8;i++)
printf("%u",ID[i]);
printf("\r\n") ;
if(flag == 500)
printf("The Temperature is:%f\r\n",Read_T());//读取温度并输出
printf("===================================================\r\n");
while (1)
#endif
#ifdef __GNUC__
#else
PUTCHAR_PROTOTYPE
return ch;
while (1)
#endif
#include
#include "spi_flash.h"
#define VREF 3.3
u8 j;
while(n--)
for(j=0;j<10;j++);
while(n--)
delay_us(1000);
#define TxBufferSize1 (countof(TxBuffer1) - 1)
#define RxBufferSize1 (countof(TxBuffer1) - 1)
#define countof(a) (sizeof(a) / sizeof(*(a)))
#define BufferSize (countof(Tx_Buffer)-1)
typedef enum { FAILED = 0, PASSED = !FAILED} TestStatus;
#define FLASH_WriteAddress 0x00000
#define FLASH_ReadAddress FLASH_WriteAddress
#define FLASH_SectorToErase FLASH_WriteAddress
#define sFLASH_ID 0xEF3015 //W25X16
//#define sFLASH_ID 0xEF4015 //W25Q16
uint8_t Tx_Buffer[4096] ;
uint8_t Rx_Buffer[BufferSize];
__IO uint32_t DeviceID = 0;
__IO uint32_t FlashID = 0;
__IO TestStatus TransferStatus1 = FAILED;
void Delay(__IO uint32_t nCount);
TestStatus Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength);
char *int_to_string(int number,char *strnum)//整形数据转换为字符型
int j=0,i=0,n=0;
char temp;
while(number>0)
*(strnum+j)=number%10+48;
j++;
number=number/10;
n++;
for(i=0;iLibraries->Small printf
#else
* @param None
* @retval None
PUTCHAR_PROTOTYPE
return ch;
* @retval None
/* Infinite loop */
while (1)
#endif
| 为遥控小车巧添功能被打赏¥26元 | |
