定时器中断
#include "stm32f10x.h"
#include "stm32_eval.h"
#include
EXTI_InitTypeDef EXTI_InitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
long flag1=0,flag2=0;
void RCC_Configuration(void)
SystemInit();//24MHZ
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_ResetBits(GPIOD,GPIO_Pin_2);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
void USART_int(long BaudRate)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* PA10 USART1_Rx */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
/* USARTx configured as follow:
- BaudRate = 115200 baud
- Word Length = 8 Bits
- One Stop Bit
- No parity
- Hardware flow control disabled (RTS and CTS signals)
- Receive and transmit enabled
USART_InitStructure.USART_BaudRate = BaudRate;//??????
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长8bit
USART_InitStructure.USART_StopBits = USART_StopBits_1//停止位1
USART_InitStructure.USART_Parity = USART_Parity_No;//?
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//收发
USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
USART_ClockInit(USART1, &USART_ClockInitStructure);
USART_Init(USART1, &USART_InitStructure);
USART_Cmd(USART1, ENABLE);
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
void NVIC_Configuration(void)
/* Enable the TIM2 global Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;//抢占式优先级
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;//响应式优先级
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
/* Enable the TIM3 global Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
/* Time base configuration */
void TIM2_Configuration(void)//2s
TIM_TimeBaseStructure.TIM_Period = 19999;//中断周期 2s
TIM_TimeBaseStructure.TIM_Prescaler = 2399;//预分频得0.1ms
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
void TIM3_Configuration(void)//1s
TIM_TimeBaseStructure.TIM_Period = 9999;//中断周期 1s
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
int main(void)
/* System Clocks Configuration */
RCC_Configuration();
NVIC_Configuration();
USART_int(115200);
TIM2_Configuration();
TIM3_Configuration();
TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE);
TIM_Cmd(TIM2, ENABLE);//
TIM_ITConfig(TIM3, TIM_IT_Update, ENABLE);
TIM_Cmd(TIM3, ENABLE);//
printf(" config done...\r\n");
while (1)
if(flag1 == 0)
printf("TIM2 interrupt......\r\n");
GPIO_SetBits(GPIOC,GPIO_Pin_0);
if(flag2 == 0)
printf("TIM3 interrupt......\r\n");
GPIO_SetBits(GPIOC,GPIO_Pin_1);
void TIM2_IRQHandler(void) //TIM2 ??
if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET)
TIM_ClearITPendingBit(TIM2, TIM_IT_Update );
GPIO_ResetBits(GPIOC,GPIO_Pin_0);
void TIM3_IRQHandler(void) //TIM3 ??
if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET)
TIM_ClearITPendingBit(TIM3, TIM_IT_Update );
GPIO_ResetBits(GPIOC,GPIO_Pin_1);
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
#ifdef __GNUC__
/* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
set to 'Yes') calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
* @brief Retargets the C library printf function to the USART.
* @param None
* @retval None
PUTCHAR_PROTOTYPE
/* Place your implementation of fputc here */
/* e.g. write a character to the USART */
USART_SendData(EVAL_COM1, (uint8_t) ch);
/* Loop until the end of transmission */
while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
return ch;
* @retval None
/* Infinite loop */
while (1)
#endif
PWM-RGB
#include
#define VREF 3.3
RCC_DeInit();
RCC_HSICmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
RCC_HSEConfig(RCC_HSE_OFF);
RCC_LSEConfig(RCC_LSE_OFF);
RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz
RCC_PLLCmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
RCC_ADCCLKConfig(RCC_PCLK2_Div4);
RCC_PCLK2Config(RCC_HCLK_Div1);
RCC_PCLK1Config(RCC_HCLK_Div2);
RCC_HCLKConfig(RCC_SYSCLK_Div1);
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
while(RCC_GetSYSCLKSource() != 0x08);
SystemInit();
- One Stop Bit
- No parity
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
USART_InitStructure.USART_Parity = USART_Parity_No;//????
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
void PWM_Config()
uint16_t PrescalerValue = 0;
/* TIM2 clock enable */
/* GPIOA enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;//PWM&RGB所在位置 PA1 PA2 PA3
/* Compute the prescaler value */
PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1;
TIM_TimeBaseStructure.TIM_Period = 0x07FF;
TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
/* PWM1 Mode configuration: Channel2 ,PA1在通道2*/
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_Pulse = 0xFFFF;
TIM_OC2Init(TIM2, &TIM_OCInitStructure);
/* PWM1 Mode configuration: Channel3 PA2在通道3*/
TIM_OC3Init(TIM2, &TIM_OCInitStructure);
/* PWM1 Mode configuration: Channel4 PA3在通道4*/
TIM_OC4Init(TIM2, &TIM_OCInitStructure);
TIM_ARRPreloadConfig(TIM2, ENABLE);
void delay_us(u32 n)
u8 j;
while(n--)
for(j=0;j<10;j++);
void delay_ms(u32 n)
while(n--)
delay_us(1000);
void PWM_TEST()
unsigned int temp0=2047,temp1=0,temp2=2047;
printf("PWM-RGB TEST......\r\n");
while(1)
for(;(temp0>0)||(temp1<2047);temp0--,temp1++)// 红色渐灭 蓝色渐亮
TIM_SetCompare2(TIM2, temp0);//temp0:2047~0
TIM_SetCompare3(TIM2, temp1);//temp1:0~2047
delay_us(1500);
for(;(temp0<2047)||(temp2>0);temp0++,temp2--)//蓝色渐灭 绿色渐亮
TIM_SetCompare2(TIM2, temp0);//temp0:0~2047
TIM_SetCompare4(TIM2, temp2);//temp2:2047~0
delay_us(1500);
for(;(temp1>0)||(temp2<2047);temp1--,temp2++)//绿色渐灭 红色渐亮
TIM_SetCompare4(TIM2, temp2);//temp2:0~2047
TIM_SetCompare3(TIM2, temp1);//temp1:2047~0
delay_us(1500);
int main(void)
USART_int(115200);
PWM_Config();
delay_ms(100);
PWM_TEST();
while (1)
#endif
#ifdef __GNUC__
#else
PUTCHAR_PROTOTYPE
return ch;
while (1)
#endif
PWM-ADC
#include <stdio.h>
#define VREF 3.3
int volt;
unsigned int temp0,temp1,temp2;
RCC_DeInit();
RCC_HSICmd(ENABLE);
RCC_PLLCmd(ENABLE);
SystemInit();
- One Stop Bit
- No parity
u8 j;
while(n--)
for(j=0;j<10;j++);
while(n--)
delay_us(1000);
void PWM_Config()
/* GPIOA enable */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;//PWM&RGB- PA1 PA2 PA3
void ADC_CONFIG(){
ADC_InitTypeDef ADC_InitStructure;
#if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL)
/* ADCCLK = PCLK2/2 */
RCC_ADCCLKConfig(RCC_PCLK2_Div2);
#else
/* ADCCLK = PCLK2/4 */
#endif
ADC_DeInit(ADC1);
/* Enable ADC1 and GPIOC clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOB, ENABLE);
/* Configure PB0 (ADC Channel14) as analog input -------------------------*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;//ADC所在端口PB0
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;//模拟输入模式
GPIO_Init(GPIOB, &GPIO_InitStructure);
/* ADC1 configuration ------------------------------------------------------*/
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
ADC_InitStructure.ADC_ScanConvMode = ENABLE;
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//ADC数据右对齐
ADC_InitStructure.ADC_NbrOfChannel = 1;//ADC通道数为1
ADC_Init(ADC1, &ADC_InitStructure);//初始化ADC1
/* Enable ADC1 DMA */
ADC_DMACmd(ADC1, ENABLE);
/* Enable ADC1 */
ADC_Cmd(ADC1, ENABLE);
int Get_ADC(){
/* ADC1 regular channel configuration */
ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 1, ADC_SampleTime_55Cycles5);//通道:8 ,采样时间
/* Enable ADC1 reset calibration register */
ADC_ResetCalibration(ADC1);//重置ADC1的校准寄存器
/* Check the end of ADC1 reset calibration register */
while(ADC_GetResetCalibrationStatus(ADC1));//确认重置完毕
/* Start ADC1 calibration */
ADC_StartCalibration(ADC1);//开始ADC1校准
/* Check the end of ADC1 calibration */
while(ADC_GetCalibrationStatus(ADC1));//确认校准完毕
/* Start ADC1 Software Conversion */
ADC_SoftwareStartConvCmd(ADC1, ENABLE);//使能ADC1软件转换功能
return ADC_GetConversionValue(ADC1);
void PWM_TEST()
/*全局变量volt,控制TIM_SetCompare2,TIM_SetCompare3,TIM_SetCompare4 的第二个参数*/
unsigned int temp0=volt,temp1=0,temp2=volt;
for(;(temp0>0)||(temp1<volt);temp0--,temp1++)// ???? ????
TIM_SetCompare2(TIM2, temp0);//temp0:volt~0
TIM_SetCompare3(TIM2, temp1);//temp1:0~volt
delay_us(1000);
for(;(temp0<volt)||(temp2>0);temp0++,temp2--)//???? ????
TIM_SetCompare2(TIM2, temp0);//temp0:0~volt
TIM_SetCompare4(TIM2, temp2);//temp2:volt~0
delay_us(1000);
for(;(temp1>0)||(temp2<volt);temp1--,temp2++)//???? ????
TIM_SetCompare4(TIM2, temp2);//temp2:0~volt
TIM_SetCompare3(TIM2, temp1);//temp1:volt~0
delay_us(1000);
int main(void)
float Volt=0.00;
int ADValue = 0;
USART_int(115200);
ADC_CONFIG();
Get_ADC();
PWM_Config();
delay_ms(1000);
while(1)
ADValue = Get_ADC();
Volt = VREF*ADValue/4095;
/*volt的值由Volt直接决定 volt是Volt乘以1000的整型值*/
volt=Volt*1000;
printf("===============================\r\n");
printf("The ADC value is:%d\r\n",ADValue);
printf("The Volt is:%f V\r\n",Volt);
printf("The volt is:%d \r\n",volt);
PWM_TEST();
delay_ms(500);
while (1)
#endif
#ifdef __GNUC__
#else
PUTCHAR_PROTOTYPE
return ch;
while (1)
#endif
系统滴答&18B20
#include <stdio.h>
volatile int flag;
#define Set_B20() GPIO_SetBits(GPIOC, GPIO_Pin_12)
#define Reset_B20() GPIO_ResetBits(GPIOC, GPIO_Pin_12)
#define Read_B20() GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_12)
unsigned char Error_Flag=0;
unsigned char zf=0;
unsigned char ID[8];
void SysTick_Configuration(void)
/* Setup SysTick Timer for 1 msec interrupts */
if (SysTick_Config(48000)) //SysTick配置 48000/48MHZ=1ms 滴答一次
/* Capture error */
while (1);
/* Configure the SysTick handler priority */
NVIC_SetPriority(SysTick_IRQn, 0x0); //SysTick中断优先级
#define RCC_PLLSource_HSE_Div1 ((uint32_t)0x00010000)
RCC_DeInit();
RCC_HSICmd(ENABLE);
RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_6); // 6*8Mhz= 48MHz
RCC_PLLCmd(ENABLE);
// SystemInit();
- One Stop Bit
- No parity
void delay_18b20(u32 nus)
u16 i;
while(nus--)
for(i=12;i>0;i--);
/*delay_us*/
u8 j;
while(n--)
for(j=0;j<10;j++);
/*delay_ms*/
while(n--)
delay_us(1000);
void Init18B20(void)//18B20初始化
u8 aa=0;
u8 count =0;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); //GPIOC的复用时钟使能
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;//选择PC12
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;//开漏输出
GPIO_Init(GPIOC, &GPIO_InitStructure);//GPIOC初始化
Set_B20() ;
/*复位时需要至少480us的低电平*/
delay_18b20(1);
Reset_B20();
delay_18b20(480);
/* 探测到上升沿后等待15~60us后18B20发出存在脉冲 */
Set_B20();
delay_18b20(480);
count=0;
aa=Read_B20();//读取18B20的一个字节 赋值给aa
/* 校验读取值,错误次数大于99才报错 */
while(!aa && count<100)
aa=Read_B20();
count++;
if(count>=99)
Error_Flag=1;
else
Error_Flag=0;
unsigned char Read18B20(void)//读取18B20的一个字节
unsigned char i=0;
unsigned char date=0;
u8 tempp;
for(i=8;i>0;i--)//按位读取,读取一个字需要循环8次
Reset_B20();//拉低电平
date>>=1;//date右移一位
delay_18b20(1);
Set_B20(); //置高电平
delay_18b20(1);
tempp=Read_B20();//读取温度值
if(tempp)//若读取到的值非0
{date|=0x80;} //将date的最高位置1
delay_18b20(60);
return(date);
void Write18B20(unsigned char date)//写入
unsigned char i=0;
for (i=8; i>0; i--)
Reset_B20(); //置低电平
delay_18b20(1);
if(date & 0x01) //如果date最低位为1
Set_B20();//置高电平
else//如果date最低位为0
Reset_B20();}//置低电平
delay_18b20(60);
date>>=1; //date右移一位
Set_B20();//置高电平
delay_18b20(1);
delay_18b20(15);
float Read_T()//读取温度值
unsigned char TUp,TDown;
unsigned char fTemp;
u8 TT=0;
float Temp = 0;
Init18B20();//1820初始化
Write18B20(0xcc); //不提供64位ROM编码使用存储器
Write18B20(0x44); //启动一次温度转换
Write18B20(0xbe); //从字节0开始读取暂存器内容
/*两次读取温度*/
TDown = Read18B20();
TUp = Read18B20();
if(TUp>0x7f) // 如果TUp的值大于最大值(11111111)bin
TDown=~TDown; //TDown取反
TUp=~TUp+1; //TUp取反加一
TUp/=8; //TUp除以8
zf=1; //zf标志位置1
else
zf=0;
fTemp=TDown&0x0f;//TDown保留后四位,赋值给fTemp
TUp<<=4;//TUp左移四位,舍去高四位
TDown>>=4;//TDown右移四位,舍去低四位
TT=TUp|TDown;//TUp与TDown合并 赋值给TT
Temp=TT+(float)fTemp/16;
return(Temp);
int main(void)
int i;
USART_int(115200);
Init18B20();//初始化18B20
SysTick_Configuration();//系统滴答时钟配置
Write18B20(0x33);//此命令获取18B20的ID
for(i=0;i<8;i++)//用一个8位的数组保存id值
ID[i]=Read18B20();
delay_ms(1000);
while(1)
void SysTick_Handler(void)
int i;
flag++;
if(flag==300)//每300ms输出一次id
printf("\r\nevent 1 oc......\r\n");
printf("The id is :\r\n");
for(i=0;i<8;i++)
printf("%u",ID[i]);
else if(flag==500)//每500ms输出一次温度
printf("\r\nevent 2 oc......\r\n");
printf("The Temperature is:%f\r\n",Read_T());
flag = 0;
* @retval None
/* Infinite loop */
while (1)
#endif
#ifdef __GNUC__
#else
* @param None
* @retval None
PUTCHAR_PROTOTYPE
return ch;
* @retval None
/* Infinite loop */
while (1)
#endif
spi串口
#include <stdio.h>
#include "spi_flash.h"
#define VREF 3.3
u8 j;
while(n--)
for(j=0;j<10;j++);
while(n--)
delay_us(1000);
#define TxBufferSize1 (countof(TxBuffer1) - 1)
#define RxBufferSize1 (countof(TxBuffer1) - 1)
#define countof(a) (sizeof(a) / sizeof(*(a)))
#define BufferSize (countof(Tx_Buffer)-1)
typedef enum { FAILED = 0, PASSED = !FAILED} TestStatus;
#define FLASH_WriteAddress 0x00000
#define FLASH_ReadAddress FLASH_WriteAddress
#define FLASH_SectorToErase FLASH_WriteAddress
#define sFLASH_ID 0xEF3015 //W25X16
//#define sFLASH_ID 0xEF4015 //W25Q16
#define buff_size 16;
char rx_buff[],rx_buff_count=0;
uint8_t Tx_Buffer[4096] ;
uint8_t Rx_Buffer[BufferSize];
__IO uint32_t DeviceID = 0;
__IO uint32_t FlashID = 0;
__IO TestStatus TransferStatus1 = FAILED;
void Delay(__IO uint32_t nCount);
TestStatus Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength);
char *int_to_string(int number,char *strnum)//整形数据转换为字符型
int j=0,i=0,n=0;
char temp;
while(number>0)
*(strnum+j)=number%10+48;
j++;
number=number/10;
n++;
for(i=0;i<n/2;i++)
temp=*(strnum+j+i-n);
*(strnum+j+i-n)=*(strnum+j-i-1);
*(strnum+j-i-1)=temp;
strnum[n]='\0';
return strnum;
RCC_DeInit();
RCC_HSICmd(ENABLE);
RCC_PLLCmd(ENABLE);
//SystemInit();
while(BufferLength--)
if(*pBuffer1 != *pBuffer2)
return FAILED;
pBuffer1++;
pBuffer2++;
return PASSED;
for(; nCount != 0; nCount--);
void ADC_CONFIG(){
#else
#endif
ADC_DeInit(ADC1);
/* Enable ADC1 */
int Get_ADC(){
void SPI_TEST()
printf("\r\n这是一个2M SPI总线flash(W25X16)测试 \r\n");
SPI_FLASH_Init();
/* Get SPI Flash Device ID */
DeviceID = SPI_FLASH_ReadDeviceID();
Delay( 200 );
/* Get SPI Flash ID */
FlashID = SPI_FLASH_ReadID();
printf("\r\n FlashID is 0x%X, Manufacturer Device ID is 0x%X\r\n", FlashID, DeviceID);
/* Check the SPI Flash ID */
if (FlashID == sFLASH_ID) /* #define sFLASH_ID 0xEF3015 */
printf("\r\n 检测到华邦flash W25X16 !\r\n");
/* Erase SPI FLASH Sector to write on */
SPI_FLASH_SectorErase(FLASH_SectorToErase);
SPI_FLASH_BufferWrite(Tx_Buffer, FLASH_WriteAddress, BufferSize);
printf("\r\n写入的数据是:%s \r\t", Tx_Buffer);
/* 读出刚才写入的数据*/
SPI_FLASH_BufferRead(Rx_Buffer, FLASH_ReadAddress, BufferSize);
printf("\r\n读出的数据是:%s \r\n", Rx_Buffer);
TransferStatus1 = Buffercmp(Tx_Buffer, Rx_Buffer, BufferSize);
if( PASSED == TransferStatus1 )
printf("\r\n 2M SPI总线flash(W25X16)测试成功!\n\r");
else
printf("\r\n 2M SPI总线flash(W25X16)测试失败!\n\r");
}// if (FlashID == sFLASH_ID)
else
printf("\r\n 未检测到 W25X16 ID!\n\r");
SPI_Flash_PowerDown();
printf("\r\n=================================================\n\r");
/* Private functions ---------------------------------------------------------*/
* @brief Main program.
* @param None
* @retval None
int main(void)
int i=0;
int ADValue = 0;
char Buffer[100];
USART_int(115200);
ADC_CONFIG();
delay_ms(1000);
while(1)
for(i=0;i<5;i++)
int_to_string(ADValue,Buffer);
Tx_Buffer[i]=Buffer[i];
SPI_TEST();
delay_ms(1000);
while (1)
#endif
#ifdef __GNUC__
#else
* @param None
* @retval None
PUTCHAR_PROTOTYPE
return ch;
while (1)
#endif
IIC-计上电次数
#include "STM32_I2C.h"
#include <stdio.h>
unsigned char i;
void EXTIkeyS1_Config(void);
/*delay_us*/
u8 j;
while(n--)
for(j=0;j<10;j++);
/*delay_ms*/
while(n--)
delay_us(1000);
RCC_DeInit();
RCC_HSICmd(ENABLE);
RCC_PLLCmd(ENABLE);
//SystemInit();
- One Stop Bit
- No parity
/* Configure four bit for preemption priority */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);
/* Enable the USART1 Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15;
void IIc2_Init(void)
I2C_InitTypeDef I2C_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C2, ENABLE);
//PB6-I2C2_SCL PB7-I2C2_SDA PB10-I2C2_SCL PB11-I2C2_SDA
/* Configure IO connected to IIC*********************/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
I2C_InitStructure.I2C_OwnAddress1 = 0xA0;
I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
I2C_InitStructure.I2C_ClockSpeed = 400000;
I2C_Cmd(I2C2, ENABLE);
I2C_Init(I2C2, &I2C_InitStructure);
I2C_AcknowledgeConfig(I2C2, ENABLE);
void I2C2_WriteByte(unsigned char id,unsigned char write_address,unsigned char byte)
while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY));
I2C_GenerateSTART(I2C2,ENABLE);
while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_MODE_SELECT));
I2C_Send7bitAddress(I2C2,id,I2C_Direction_Transmitter);
while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
I2C_SendData(I2C2, write_address);
while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
I2C_SendData(I2C2, byte);
I2C_GenerateSTOP(I2C2, ENABLE);
do
/* Send START condition */
I2C_GenerateSTART(I2C2, ENABLE);
/* Read I2C2 SR1 register */
/* Send EEPROM address for write */
I2C_Send7bitAddress(I2C2, 0xA0, I2C_Direction_Transmitter);
}while(!(I2C_ReadRegister(I2C2, I2C_Register_SR1) & 0x0002));
/* Clear AF flag */
I2C_ClearFlag(I2C2, I2C_FLAG_AF);
/* STOP condition */
unsigned char I2C2_ReadByte(unsigned char id, unsigned char read_address)
unsigned char temp;
while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY)){}
I2C_Send7bitAddress(I2C2, id, I2C_Direction_Transmitter);
I2C_SendData(I2C2, read_address);
I2C_Send7bitAddress(I2C2, id, I2C_Direction_Receiver);
while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
I2C_AcknowledgeConfig(I2C2, DISABLE);
while(!(I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_RECEIVED)));
temp = I2C_ReceiveData(I2C2);
return temp;
int main(void)
EXTIkeyS1_Config();
USART_int(115200);
IIc2_Init();
i = I2C2_ReadByte(0xA0,0);//向0x00读取数据
printf("从地址0x00读出数据 :%d\r\n",i);
i++;
I2C2_WriteByte(0xA0,0,i);//向0x00写入数据
printf("向地址0x00写入数据 :%d\r\n",i);
while(1)
delay_ms(2000);
printf(" 上电次数为%d\r\n",i);
void EXTIkeyS1_Config(void)//S1 PC8
/* Enable GPIOA clock */
/* Configure PA.00 pin as input floating */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;//PC8 S1
/* Enable AFIO clock */
GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource8);
EXTI_InitStructure.EXTI_Line = EXTI_Line8;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure);
NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
void EXTI9_5_IRQHandler(void)
if(EXTI_GetITStatus(EXTI_Line8) != RESET)
i=0;
I2C2_WriteByte(0xA0,0,0);
/* Clear the EXTI line 8 pending bit */
EXTI_ClearITPendingBit(EXTI_Line8);
while (1)
#endif
#ifdef __GNUC__
#else
PUTCHAR_PROTOTYPE
return ch;
while (1)
#endif
| 为遥控小车巧添功能被打赏¥26元 | |
