【简介】
Ozone 作为SEGGER 的生态之一对于SEGGER的支持是很完善的,在使用JLINK的开发中有些场合会使用到RTT的打印功能。我们基于OZONE来使用RTT 终端来输出日志信息,RTT的移植适配是是很简单的只要把对应的代码加入到工程之中就可以。本地使用的JLINK 8.20 的驱动在安装目录中就可以获取到对应的源代码文件,本地的路径如下:
把上述的源代码加入到工程编译,解决掉相关的编译问题就完成了RTT的代码适配
代码添加完成后添加如下的测试代码来验证RTT 的输出功能
* main
int rtt_test_main(void) {
SEGGER_RTT_ConfigUpBuffer(0, NULL, NULL, 0, SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL);
SEGGER_RTT_WriteString(0, "SEGGER Real-Time-Terminal Sample\r\n\r\n");
SEGGER_RTT_WriteString(0, "###### Testing SEGGER_printf() ######\r\n");
SEGGER_RTT_printf(0, "printf Test: %%c, 'S' : %c.\r\n", 'S');
SEGGER_RTT_printf(0, "printf Test: %%5c, 'E' : %5c.\r\n", 'E');
SEGGER_RTT_printf(0, "printf Test: %%-5c, 'G' : %-5c.\r\n", 'G');
SEGGER_RTT_printf(0, "printf Test: %%5.3c, 'G' : %-5c.\r\n", 'G');
SEGGER_RTT_printf(0, "printf Test: %%.3c, 'E' : %-5c.\r\n", 'E');
SEGGER_RTT_printf(0, "printf Test: %%c, 'R' : %c.\r\n", 'R');
SEGGER_RTT_printf(0, "printf Test: %%s, \"RTT\" : %s.\r\n", "RTT");
SEGGER_RTT_printf(0, "printf Test: %%s, \"RTT\\r\\nRocks.\" : %s.\r\n", "RTT\r\nRocks.");
SEGGER_RTT_printf(0, "printf Test: %%u, 12345 : %u.\r\n", 12345);
SEGGER_RTT_printf(0, "printf Test: %%+u, 12345 : %+u.\r\n", 12345);
SEGGER_RTT_printf(0, "printf Test: %%.3u, 12345 : %.3u.\r\n", 12345);
SEGGER_RTT_printf(0, "printf Test: %%.6u, 12345 : %.6u.\r\n", 12345);
SEGGER_RTT_printf(0, "printf Test: %%6.3u, 12345 : %6.3u.\r\n", 12345);
SEGGER_RTT_printf(0, "printf Test: %%8.6u, 12345 : %8.6u.\r\n", 12345);
SEGGER_RTT_printf(0, "printf Test: %%08u, 12345 : %08u.\r\n", 12345);
SEGGER_RTT_printf(0, "printf Test: %%08.6u, 12345 : %08.6u.\r\n", 12345);
SEGGER_RTT_printf(0, "printf Test: %%0u, 12345 : %0u.\r\n", 12345);
SEGGER_RTT_printf(0, "printf Test: %%-.6u, 12345 : %-.6u.\r\n", 12345);
SEGGER_RTT_printf(0, "printf Test: %%-6.3u, 12345 : %-6.3u.\r\n", 12345);
SEGGER_RTT_printf(0, "printf Test: %%-8.6u, 12345 : %-8.6u.\r\n", 12345);
SEGGER_RTT_printf(0, "printf Test: %%-08u, 12345 : %-08u.\r\n", 12345);
SEGGER_RTT_printf(0, "printf Test: %%-08.6u, 12345 : %-08.6u.\r\n", 12345);
SEGGER_RTT_printf(0, "printf Test: %%-0u, 12345 : %-0u.\r\n", 12345);
SEGGER_RTT_printf(0, "printf Test: %%u, -12345 : %u.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%+u, -12345 : %+u.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%.3u, -12345 : %.3u.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%.6u, -12345 : %.6u.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%6.3u, -12345 : %6.3u.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%8.6u, -12345 : %8.6u.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%08u, -12345 : %08u.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%08.6u, -12345 : %08.6u.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%0u, -12345 : %0u.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%-.6u, -12345 : %-.6u.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%-6.3u, -12345 : %-6.3u.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%-8.6u, -12345 : %-8.6u.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%-08u, -12345 : %-08u.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%-08.6u, -12345 : %-08.6u.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%-0u, -12345 : %-0u.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%d, -12345 : %d.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%+d, -12345 : %+d.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%.3d, -12345 : %.3d.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%.6d, -12345 : %.6d.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%6.3d, -12345 : %6.3d.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%8.6d, -12345 : %8.6d.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%08d, -12345 : %08d.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%08.6d, -12345 : %08.6d.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%0d, -12345 : %0d.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%-.6d, -12345 : %-.6d.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%-6.3d, -12345 : %-6.3d.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%-8.6d, -12345 : %-8.6d.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%-08d, -12345 : %-08d.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%-08.6d, -12345 : %-08.6d.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%-0d, -12345 : %-0d.\r\n", -12345);
SEGGER_RTT_printf(0, "printf Test: %%x, 0x1234ABC : %x.\r\n", 0x1234ABC);
SEGGER_RTT_printf(0, "printf Test: %%+x, 0x1234ABC : %+x.\r\n", 0x1234ABC);
SEGGER_RTT_printf(0, "printf Test: %%.3x, 0x1234ABC : %.3x.\r\n", 0x1234ABC);
SEGGER_RTT_printf(0, "printf Test: %%.6x, 0x1234ABC : %.6x.\r\n", 0x1234ABC);
SEGGER_RTT_printf(0, "printf Test: %%6.3x, 0x1234ABC : %6.3x.\r\n", 0x1234ABC);
SEGGER_RTT_printf(0, "printf Test: %%8.6x, 0x1234ABC : %8.6x.\r\n", 0x1234ABC);
SEGGER_RTT_printf(0, "printf Test: %%08x, 0x1234ABC : %08x.\r\n", 0x1234ABC);
SEGGER_RTT_printf(0, "printf Test: %%08.6x, 0x1234ABC : %08.6x.\r\n", 0x1234ABC);
SEGGER_RTT_printf(0, "printf Test: %%0x, 0x1234ABC : %0x.\r\n", 0x1234ABC);
SEGGER_RTT_printf(0, "printf Test: %%-.6x, 0x1234ABC : %-.6x.\r\n", 0x1234ABC);
SEGGER_RTT_printf(0, "printf Test: %%-6.3x, 0x1234ABC : %-6.3x.\r\n", 0x1234ABC);
SEGGER_RTT_printf(0, "printf Test: %%-8.6x, 0x1234ABC : %-8.6x.\r\n", 0x1234ABC);
SEGGER_RTT_printf(0, "printf Test: %%-08x, 0x1234ABC : %-08x.\r\n", 0x1234ABC);
SEGGER_RTT_printf(0, "printf Test: %%-08.6x, 0x1234ABC : %-08.6x.\r\n", 0x1234ABC);
SEGGER_RTT_printf(0, "printf Test: %%-0x, 0x1234ABC : %-0x.\r\n", 0x1234ABC);
SEGGER_RTT_printf(0, "printf Test: %%p, &_Cnt : %p.\r\n", &_Cnt);
SEGGER_RTT_WriteString(0, "###### SEGGER_printf() Tests done. ######\r\n");
return 0;
}代码添加完成后我们在OZONE中打开终端
程序运行后就会在终端中捕获到对应的日志信息了
