电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 【10月更新】28的学习进程
共14条 2/2 ‹ 1 2 跳转至页
2015-10-24 20:53:49     打赏
11楼
MDK的安装
1.找到找到安装包的,双击mdk472_a.exe,开始安装
2、按照安装向导来,勾选后,点击next、next、next
3、出现安装中的界面,等待中
4、安装成功后,点击桌面MDK快捷方式,出现如下界面:
5、点击File—License management,出现如下界面:
6、打开和谐文件,将上图中的CID复制到下图的对应位置,勾选如下图所示的选项:
7、多次点击上图下方中的Generate,将其上方框框中的一大串字符,复制到New LIC中,如下图:
7、点击Add LIC,出现界面如下:
8、关闭该软件后重新打开,和谐版完成!
2015-11-08 18:02:24     打赏
12楼
第二次作业:流水灯
  * @file    GPIO/IOToggle/main.c
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    08-April-2011
  * @brief   Main program body.
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32_eval.h"
GPIO_InitTypeDef GPIO_InitStructure;
void RCC_Configuration(void)
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  RCC_HSEConfig(RCC_HSE_OFF);
  RCC_LSEConfig(RCC_LSE_OFF);
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  RCC_PLLCmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  RCC_PCLK2Config(RCC_HCLK_Div1);
  RCC_PCLK1Config(RCC_HCLK_Div2);
  RCC_HCLKConfig(RCC_SYSCLK_Div1);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  while(RCC_GetSYSCLKSource() != 0x08);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
 GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_ResetBits(GPIOD,GPIO_Pin_2);
void delay_us(u32 n)
u8 j;
while(n--)
for(j=0;j<10;j++);
void delay_ms(u32 n)
while(n--)
delay_us(1000);
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
{ unsigned char flag=0;
RCC_Configuration();
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
 GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
while(1)
GPIO_SetBits(GPIOC,GPIO_Pin_0);
GPIO_SetBits(GPIOC,GPIO_Pin_1);
GPIO_SetBits(GPIOC,GPIO_Pin_2);
GPIO_SetBits(GPIOC,GPIO_Pin_3);
GPIO_SetBits(GPIOC,GPIO_Pin_4);
GPIO_SetBits(GPIOC,GPIO_Pin_5);
GPIO_SetBits(GPIOC,GPIO_Pin_6);
GPIO_SetBits(GPIOC,GPIO_Pin_7);
 delay_ms(100);
    GPIO_ResetBits(GPIOC,GPIO_Pin_0);
delay_ms(100);
delay_ms(100);
GPIO_ResetBits(GPIOC,GPIO_Pin_1);
delay_ms(100);
delay_ms(100);
GPIO_ResetBits(GPIOC,GPIO_Pin_2);
delay_ms(100);
delay_ms(100);
GPIO_ResetBits(GPIOC,GPIO_Pin_3);
delay_ms(100);
delay_ms(100);
GPIO_ResetBits(GPIOC,GPIO_Pin_4);
delay_ms(100);
delay_ms(100);
GPIO_ResetBits(GPIOC,GPIO_Pin_5);
delay_ms(100);
delay_ms(100);
GPIO_ResetBits(GPIOC,GPIO_Pin_6);
delay_ms(100);
delay_ms(100);
GPIO_ResetBits(GPIOC,GPIO_Pin_7);
delay_ms(100);
delay_ms(100);
2015-11-18 11:06:21     打赏
13楼
2015-11-19 22:38:44     打赏
14楼
共14条 2/2 ‹ 1 2 跳转至页
