电子产品世界 » 论坛首页 » 嵌入式开发 » 软件与操作系统 » mealy&moore状态机典型程序- -
2015-04-06 20:55:58     打赏
Verilog
// Example of a 5-state Mealy FSM
module mealy (data_in, data_out, reset, clock);
output data_out;
input [1:0] data_in;
input reset, clock;
reg data_out;
reg [2:0] pres_state, next_state;
parameter st0=3'd0, st1=3'd1, st2=3'd2, st3=3'd3, st4=3'd4;
// FSM register
always @ (posedge clock or negedge reset)
begin: statereg
if(!reset)// asynchronous reset
pres_state = st0;
else
pres_state = next_state;
end // statereg
// FSM combinational block
always @(pres_state or data_in)
begin: fsm
case (pres_state)
st0:    case(data_in)
2'b00:       next_state=st0;
2'b01:       next_state=st4;
2'b10:       next_state=st1;
2'b11:       next_state=st2;
endcase
st1:    case(data_in)
2'b10:       next_state=st2;
default:     next_state=st1;
endcase
st2:    case(data_in)
2'b0x:       next_state=st1;
2'b1x:       next_state=st3;
endcase
st3:    case(data_in)
2'bx1:       next_state=st4;
default:     next_state=st3;
endcase
st4:    case(data_in)
2'b11:       next_state=st4;
default:     next_state=st0;
endcase
endcase
end // fsm
// Mealy output definition using pres_state w/ data_in
always @(data_in or pres_state)
begin: outputs
case(pres_state)
st0:    case(data_in)
2'b00:      data_out=1'b0;
default:     data_out=1'b1;
endcase
st1:      data_out=1'b0;
st2:    case(data_in)
2'b0x:      data_out=1'b0;
endcase
st3:      data_out=1'b1;
st4:    case(data_in)
2'b1x:      data_out=1'b1;
default:     data_out=1'b0;
endcase
endcase
end // outputs
endmodule
Verilog
// Example of a 5-state Moore FSM
module moore (data_in, data_out, reset, clock);
output data_out;
input reset, clock;
reg data_out;
//FSM register
always @(posedge clock or negedge reset)
begin: statereg
if(!reset)
pres_state = st0;
else
end // statereg
begin: fsm
case (pres_state)
st0:    case(data_in)
endcase
st1:    case(data_in)
endcase
st2:    case(data_in)
endcase
st3:    case(data_in)
endcase
st4:    case(data_in)
endcase
default:                     next_state
=st0;
endcase
end // fsm
// Moore output definition using pres_state only
always @(pres_state)
begin: outputs
case(pres_state)
st0:     data_out=1'b1;
st1:     data_out=1'b0;
st2:     data_out=1'b1;
st3:     data_out=1'b0;
st4:     data_out=1'b1;
endcase
