电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 【1.25更新】18的作业进程
共8条 1/1 1 跳转至
【1.25更新】18的作业进程
2015-11-16 13:10:18     打赏
2015-11-16 13:16:01     打赏
第一次作业:安装
2015-11-16 13:19:11     打赏
第二次作业:
2015-11-16 13:39:39     打赏
#include "stm32f10x.h"
GPIO_InitTypeDef GPIO_InitStructure; //
void RCC_Configuration(void);
void GPIO_INIT(void) ;
void Function(void) ;
int main(void)
    RCC_Configuration();
    GPIO_INIT();
    Function();
void RCC_Configuration(void)    //
        ErrorStatus HSEStartUpStatus;   //
    RCC_DeInit();                       //
    RCC_HSEConfig(RCC_HSE_ON);//
  HSEStartUpStatus = RCC_WaitForHSEStartUp();  //
  if(HSEStartUpStatus==SUCCESS)
        RCC_HCLKConfig(RCC_SYSCLK_Div1);//
        RCC_PCLK1Config(RCC_HCLK_Div2);//
        RCC_PCLK2Config(RCC_HCLK_Div1);//
        RCC_PLLCmd(ENABLE);//
        while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)==RESET);//
        RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//
        while(RCC_GetSYSCLKSource() != 0x08);//
    GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); //
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;       //
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;         //
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;      //
    GPIO_Init(GPIOD, &GPIO_InitStructure);     //
    GPIO_ResetBits(GPIOD,GPIO_Pin_2);
void delay_us(u32 n)        //
    u8 j;
    while(n--)
            for(j=0;j<10;j++);
void  delay_ms(u32 n)       //
   while(n--)
   delay_us(1000);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOB, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
        GPIO_Init(GPIOC, &GPIO_InitStructure);  //
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_1|GPIO_Pin_15|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14;//
        GPIO_Init(GPIOB, &GPIO_InitStructure);
void Number(int a)  //
    switch(a)
        case 0 : GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);break;
        case 1 : GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);break;
        case 2 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);break;
        case 3 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);break;
        case 4 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12);break;
        case 5 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_14);break;
        case 6 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);break;
        case 7 : GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);break;
        case 8 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);break;
        case 9 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14); break;
void Function(void)
        int i=0,j=0;          //
        GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
        delay_ms(50); //
        while(1)
                GPIO_SetBits(GPIOB,GPIO_Pin_1);         //
                Number(i);                                //
                delay_ms(j);
                GPIO_ResetBits(GPIOB,GPIO_Pin_1);        //
                GPIO_SetBits(GPIOB,GPIO_Pin_15);           //
                Number(j);
                delay_ms(j);
                GPIO_ResetBits(GPIOB,GPIO_Pin_15);      //
                if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8))   //
                    delay_ms(50);            //
                        i++;                     //
                        if(i==10)
                            j++;
                            i=0;
                        if(j==10)
                             j=0;
                                                 i=0;
参考大神的作业改了一下
2015-11-29 23:13:56     打赏
第四次作业:
#include "stm32_eval.h"
#include "stdbool.h"
int main(void)
    GPIO_INIT();
    Function();
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  RCC_HSEConfig(RCC_HSE_OFF);
  RCC_LSEConfig(RCC_LSE_OFF);
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  RCC_PLLCmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);
void GPIO_INIT()
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8
|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
    while(n--)
    delay_us(1000);
  void Function(void)
        int i=0,j=0;
        delay_ms(50);
        while(1)
                Number(i);
                delay_ms(50);
                Number(j);
                delay_ms(50);
                    delay_ms(50);
                        i++;
                        if(i==10)
                            j++;
                            i=0;
                        if(j==10)
                             j=0;
                                                 i=0;
  * @brief  Main program.
  * @param  None
  * @retval None
2015-11-29 23:19:48     打赏
第五次作业:
2016-01-16 22:40:47     打赏
7楼
第六次作业
2016-01-25 13:05:43     打赏
8楼
期末二选一项目:灯颜色随温度变化而变化
iew plaincopy to clipboardprint?
#include "stdio.h"
int fputc(int ch,FILE *f);
/********************RCC配置*********************/
    RCC_DeInit();
        RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9);//*设置PLL输入时钟源8x9=72M
        RCC_PLLCmd(ENABLE);//*打开PLL:
        while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)==RESET);//*等待PLL工作:
        RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//*设置系统时钟
    /**蜂鸣器*/
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;       //#管脚号  关闭蜂鸣器
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;       //#输出速度
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;        //#输入输出模式(推挽输出)
    GPIO_Init(GPIOD, &GPIO_InitStructure);       //#初始化
void delay_us(u32 n)        //延时函数
    u8 j;
    while(n--)
            for(j=0;j<10;j++);
void  delay_ms(u32 n)       //延时函数
   while(n--)
   delay_us(1000);
/*****************************GPIO初始********************************/
void GPIO_Inits(void)
{   /*结构体初始化及开启外设时钟*/
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);
        /*GPIOA--RGB初始化*/
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_Init(GPIOA,&GPIO_InitStructure);
        GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3)
/**************************DS18B20**********************/
uint8_t DS18B20_Init(void)
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    Set_B20();
    DS18B20_Rst();
    return DS18B20_Presence ();
static void DS18B20_Mode_IPU(void)
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
static void DS18B20_Mode_Out_PP(void)
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
static void DS18B20_Rst(void)
    /* 主机设置为输出 */
    DS18B20_Mode_Out_PP();
    Reset_B20() ;
    delay_us(700);
    Set_B20()   ;
    delay_us(15);
static uint8_t DS18B20_Presence(void)
    uint8_t pulse_time = 0;
    /* 主机设置为上拉输入 */
    DS18B20_Mode_IPU();
    while( Read_B20() && pulse_time<100 )
        pulse_time++;
        delay_us(1);
    /* 经过100us后,存在脉冲都还没有到来*/
    if( pulse_time >=100 )
        return 1;
    else
        pulse_time = 0;
    /* 存在脉冲到来,且存在的时间不能超过240us */
    while( !Read_B20() && pulse_time<240 )
        pulse_time++;
        delay_us(1);
    if( pulse_time >=240 )
        return 1;
    else
        return 0;
static uint8_t DS18B20_ReadBit(void)
    uint8_t dat;
    /* 读0和读1的时间至少要大于60us */
    Reset_B20();
    delay_us(10);
    DS18B20_Mode_IPU();
    //Delay_us(2);
    if( Read_B20() == SET )
        dat = 1;
    else
        dat = 0;
    delay_us(45);
    return dat;
static uint8_t DS18B20_ReadByte(void)
    uint8_t i, j, dat = 0;
    for(i=0; i<8; i++)
        j = DS18B20_ReadBit();
        dat = (dat) | (j<<i);
    return dat;
static void DS18B20_WriteByte(uint8_t dat)
    uint8_t i, testb;
    for( i=0; i<8; i++ )
        testb = dat&0x01;
        dat = dat>>1;
        /* 写0和写1的时间至少要大于60us */
        if (testb)
            Reset_B20();
            /* 1us < 这个延时 < 15us */
            delay_us(8);
            Set_B20();
            delay_us(58);
        else
            Reset_B20();
            /* 60us < Tx 0 < 120us */
            delay_us(70);
            Set_B20();
            delay_us(2);
static void DS18B20_SkipRom ( void )
    DS18B20_Rst();
    DS18B20_Presence();
    DS18B20_WriteByte(0XCC);        /* 跳过 ROM */
static void DS18B20_MatchRom ( void )
    DS18B20_Rst();
    DS18B20_Presence();
    DS18B20_WriteByte(0X55);        /* 匹配 ROM */
float DS18B20_GetTemp_SkipRom ( void )
    uint8_t tpmsb, tplsb;
    short s_tem;
    float f_tem;
    DS18B20_SkipRom ();
    DS18B20_WriteByte(0X44);                /* 开始转换 */
    DS18B20_SkipRom ();
  DS18B20_WriteByte(0XBE);              /* 读温度值 */
    tplsb = DS18B20_ReadByte();
    tpmsb = DS18B20_ReadByte();
    s_tem = tpmsb<<8;
    s_tem = s_tem | tplsb;
    if( s_tem < 0 )      /* 负温度 */
        f_tem = (~s_tem+1) * 0.0625;
    else
        f_tem = s_tem * 0.0625;
    return f_tem;
void DS18B20_ReadId ( uint8_t * ds18b20_id )
    uint8_t uc;
    DS18B20_WriteByte(0x33);       //读取序列号
    for ( uc = 0; uc < 8; uc ++ )
      ds18b20_id [ uc ] = DS18B20_ReadByte();
float DS18B20_GetTemp_MatchRom ( uint8_t * ds18b20_id )
    uint8_t tpmsb, tplsb, i;
    short s_tem;
    float f_tem;
    DS18B20_MatchRom ();            //匹配ROM
  for(i=0;i<8;i++)
        DS18B20_WriteByte ( ds18b20_id [ i ] );
    for(i=0;i<8;i++)
    s_tem = tpmsb<<8;
    else
    return f_tem;
int main()
uint8_t uc, ucDs18b20Id [ 8 ];
GPIO_Inits();
USART_int(9600);
while( DS18B20_Init() )
printf("\r\n no ds18b20 exit \r\n");
printf("\r\n Yes ds18b20 \r\n");
DS18B20_ReadId ( ucDs18b20Id  );           // 读取 DS18B20 的序列号
printf("\r\nDS18B20的序列号是: 0x");
for ( uc = 0; uc < 8; uc ++ )             // 打印 DS18B20 的序列号
printf ( "%.2x", ucDs18b20Id [ uc ] );
for(;;)
static unsigned int i=0;
float a,b;
if(i==10)
printf ( "\r\n第10秒:温度: %.1f\r\n", DS18B20_GetTemp_MatchRom ( ucDs18b20Id ) );       // 打印通过 DS18B20 序列号获取的温度值
a=DS18B20_GetTemp_MatchRom ( ucDs18b20Id );
delay_ms(1000);     /* 1s 读取一次温度值 */
i++;
else{}
if(i<10)
printf ( "\r\n温度: %.1f\r\n", DS18B20_GetTemp_MatchRom ( ucDs18b20Id ) );        // 打印通过 DS18B20 序列号获取的温度值
i++;
if(i>10)
printf ( "\r\n10秒后:温度: %.1f\r\n", DS18B20_GetTemp_MatchRom ( ucDs18b20Id ) );       // 打印通过 DS18B20 序列号获取的温度值
b=DS18B20_GetTemp_MatchRom ( ucDs18b20Id );
i++;
if((b-a)>0.9)
{GPIO_ResetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3);
else{}
if((b-a)<0.9)
        GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3);
else{}
else{}
USART_SendData(USART1, (uint8_t) ch);
while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET)
return ch;
共8条 1/1 1 跳转至
