#include "mbed.h" #include "device.h" DigitalIn mybutton(USER_BUTTON); DigitalOut myled(LED1); DigitalOut myBZ(D0); DigitalOut AB(D6); DigitalOut CP(D7); BusOut myLEDcom(A0,A1,A2,A3,A4,A5); unsigned char LED_mode; unsigned char LEDdata; void Transmit_SN74H164(unsigned char Data) { unsigned char i; for(i=0;i<8;i++) { CP=0; // _nop_(); wait_us(1); // AB=(bit)(Data&0x80); if(Data&0x80){AB=1;}else{AB=0;} // _nop_(); wait_us(1); CP=1; // _nop_(); wait_us(1); Data<<=1; } } int main() { // unsigned char LED_mode; // unsigned char LEDdata; myLEDcom=0xff; while(1) { if (mybutton == 0) { // Button is pressed myled = !myled; // Toggle the LED state myBZ = !myBZ; LED_mode++; if(LED_mode>9)LED_mode=0; switch(LED_mode) { case 0: LEDdata=0xc0; break; case 1: LEDdata=0xf9; break; case 2: LEDdata=0xa4; break; case 3: LEDdata=0xb0; break; case 4: LEDdata=0x99; break; case 5: LEDdata=0x92; break; case 6: LEDdata=0x82; break; case 7: LEDdata=0xf8; break; case 8: LEDdata=0x80; break; case 9: LEDdata=0x90; break; } // wait(0.2); // 200 ms myLEDcom=0xff; Transmit_SN74H164(LEDdata); myLEDcom=0xfe; wait(0.2); // 200 ms } } }
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
