电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » snapdragon410c评测篇之一板子组装和安卓性能测试
2016-01-20 21:23:49     打赏
    有幸获得www.eepw.com.cn论坛提供的高通snapdragon410c板子进行评测,心中甚是激动,毕竟玩了这么久ARM处理器,看到板载功能齐全的模块,售价为75刀,相信我们心里都有一些激动。
    首先我们来看下高通是怎么介绍这块板子的:
Processor
Qualcomm Snapdragon 410
Quad-core ARM® Cortex® A53 at up to 1.2 GHz per core
64-Bit capable
Qualcomm Adreno 306 400MHz GPU for PC-class graphics with support for
advanced APIs, including OpenGL ES 3.0, OpenCL, DirectX, and content security
Memory/Storage
1GB LPDDR3 533MHz
8GB eMMC 4.51
SD 3.0 (UHS-I)
Video
1080p@30fps HD video playback and capture with H.264 (AVC), and 720p
playback with H.265 (HEVC)
Camera Support
Integrated ISP with support for image sensors up to 13MP
Audio
PCM/AAC+/MP3/WMA, ECNS, Audio+ post-processing (optional)
Connectivity
WLAN 802.11 b/g/n 2.4GHz
Bluetooth 4.1
One USB 2.0 micro B (device mode only)
Two USB 2.0 (host mode only)
GPS
On-board GPS antenna
On-board BT and WLAN antenna
I/O Interfaces
One 40-pin Low Speed (LS) expansion connector
• UART, SPI, I2S, I2C x2, GPIO x12, DC power
One 60-pin High Speed (HS) expansion connector
• 4L-MIPI DSI, USB, I2C x2, 2L+4L-MIPI CSI
Footprint for one optional 16-pin analog expansion connector for stereo headset/
line-out, speaker and analog line-in
The board can be made compatible with Arduino using an add-on mezzanine
board
External Storage
Micro SD card slotUser Interface
Power/Reset
Volume Up/down
6 LED indicators
• 4 - user controllable
• 2 - for radios (BT and WLAN activity)
OS-support
Android 5.1
Linux based on Debian
Windows 10 IoT core
Power,Mechanical and Environmental
Power: +6.5V to +18V
Dimensions: 54mm by 85mm meeting 96Boards™ Consumer Edition standard
dimensions specifications.
Operating Temp: 0°C to +70°C
RoHS and Reach compliant
    介绍完板子的特性,从一个嵌入式爱好者角度来看,吸引我最大就是 linux  android5.1和win10的系统支持,同时还有板载的BLE,GPS和WIFI模块,这大大提高了板子的使用效率,也从另外一个方面印证了高通的“开箱即用”的理念。同时作为一个智能家居和穿戴电子爱好者,该板子的丰富接口,高清视频显示也让我给这块板子打出了高分。
   首先来看下板子的高清大照:
具体都有哪些功能模块和板子接口呢?看下图:
 板载资源有个大概了解之后,看下板子的配套传感器模块:
自上而下 从左到右的模块分别为:
snapdragon 410C主板
I2C转换模块,可将传感器获得I2c电平转换为snapdragon 410c适合的电平
心率传感器模块
颜色传感器模块
光传感器模块
    以上的各种模块接口都为I2c,这也就不难明白为什么snapdragon 410c的包装盒子里有那么多的4pin线了。
下面进行开机测试:
    通过阅读手册发现,板子已经烧写好了安卓系统,只需要通电开机即可,步骤如下:
1、查看拨码开关全部处在0000位置;
2、通过HDMI线将板子和具有HDMI接口的显示器连接起来。我这里有HDMI接口的电视,就用电视作为显示器,同时插上USB接口的鼠标和键盘。
3、让snapdragon 410c通电,等待。因为首次开机,时间稍微有点长。
4、开机之后,可以利用鼠标和键盘进行各种操作。
用鼠标点开火狐浏览器,让我们在大屏幕上看下高通的主页
既然是安卓系统,来个在线电视直播软件,来测试下wifi性能和板子的图像处理能力:依旧是体育台,依旧是10号的背影,熟悉体育频道的都知道这个事广告,为什么会有重影呢?这个谁能帮忙回答下?
看起在线直播,刚刚的。
    有了直观的直播,下面有安兔兔跑下,看看板子的性能如何:
从跑分的结果上看,各项跑分都很给力,就是显示不支持3D,下一步要看下芯片的手册。
最后,来看下安卓系统的特性:
看了这个配置,你是否也心动来一块板子呢?
关键词: snapdragon410c     安卓     评测
