电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » unique-binary-search-trees-ii
2018-01-13 21:08:12     打赏
Given n, generate all structurally unique BST's (binary search trees) that store values 1...n.
For example,
Given n = 3, your program should return all 5 unique BST's shown below.
   1         3     3      2      1
     3     2     1      1   3      2
   2     1         2                 3
confused what"{1,#,2,3}"means? > read more on how binary tree is serialized on OJ.
OJ's Binary Tree Serialization:
The serialization of a binary tree follows a level order traversal, where '#' signifies a path terminator where no node exists below.
Here's an example:
   1
 2   3
   4
     5
The above binary tree is serialized as"{1,2,3,#,#,4,#,#,5}".
题意:输出1到n组成的所有二叉搜索树的结构
思路:
选定1-n的一个数字i作为根节点、0到i-1是左子树, i+1-n是右子树,两层循环;
[cpp] view plain copy
  1. class Solution
  2. {
  3. public:
  4.     vector<TreeNode*> generateTrees(int n)
  5.     {
  6.         return create(1, n);
  7.     }
  8.
  9.     vector<TreeNode*> create(int left, int right)
  10.     {
  11.         vector<TreeNode*> res;
  12.         if (left>right)
  13.         {
  14.             res.push_back(NULL);
  15.             return res;
  16.         }
  17.
  18.         for (int i=left; i<=right; i++)
  19.         {
  20.             vector<TreeNode*> leftTree = create(left, i-1);
  21.             vector<TreeNode*> rightTree = create(i+1, right);
  22.
  23.             for (int j = 0; j<leftTree.size(); j++)
  24.             {
  25.                 for (int k = 0; k<rightTree.size(); k++)
  26.                 {
  27.                     TreeNode* root = new TreeNode(i);
  28.                     root->left = leftTree[j];
  29.                     root->right = rightTree[k];
  30.
  31.                     res.push_back(root);
  32.                 }
  33.             }
  34.         }
  35.
  36.         return res;
  37.     }
  38. };
2018-01-14 11:04:11     打赏
谢谢分享源码。
