Given two binary trees, write a function to check if they are equal or not.
Two binary trees are considered equal if they are structurally identical and the nodes have the same value.
题意:判断两个树是否相等
class Solution
public:
bool isSameTree(TreeNode* p, TreeNode* q)
if (p==NULL && q==NULL)
return true;
if (p==NULL || q==NULL)
return false;
if (p->val!=q->val)
return false;
return isSameTree(p->left, q->left) && isSameTree(p->right, q->right);
