电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » binary-tree-level-order-traversal-ii
2018-01-22 17:17:51     打赏
Given a binary tree, return the bottom-up level order traversal of its nodes' values. (ie, from left to right, level by level from leaf to root).
For example:
Given binary tree{3,9,20,#,#,15,7},
    3
  9  20
   15   7
return its bottom-up level order traversal as:
  [15,7]
  [9,20],
  [3],
confused what"{1,#,2,3}"means? > read more on how binary tree is serialized on OJ.
OJ's Binary Tree Serialization:
The serialization of a binary tree follows a level order traversal, where '#' signifies a path terminator where no node exists below.
Here's an example:
   1
 2   3
   4
     5
The above binary tree is serialized as"{1,2,3,#,#,4,#,#,5}".
思路:层次遍历二叉树,然后再进行逆序操作;
[cpp] view plain copy
  1. class Solution {
  2. public:
  3.     vector<vector<int>> levelOrderBottom(TreeNode* root)
  4.     {
  5.         vector<vector<int>> res;
  6.
  7.         if (root == NULL)
  8.         {
  9.             return res;
  10.         }
  11.
  12.         queue<TreeNode*> q;
  13.         q.push(root);
  14.
  15.         while (q.size()>0)
  16.         {
  17.             vector<int> level;
  18.             for (int i = 0, n = q.size(); i<n; i++)
  19.             {
  20.                 TreeNode* tmp = q.front();
  21.                 q.pop();
  22.
  23.                 level.push_back(tmp->val);
  24.
  25.                 if (tmp->left)
  26.                 {
  27.                     q.push(tmp->left);
  28.                 }
  29.                 if (tmp->right)
  30.                 {
  31.                     q.push(tmp->right);
  32.                 }
  33.             }
  34.
  35.             res.push_back(level);
  36.         }
  37.
  38.         reverse(res.begin(), res.end());
  39.
  40.         return res;
  41.     }
  42. };
