Given a binary tree, return the bottom-up level order traversal of its nodes' values. (ie, from left to right, level by level from leaf to root).
For example:
Given binary tree{3,9,20,#,#,15,7},
3 / \ 9 20 / \ 15 7
return its bottom-up level order traversal as:
[ [15,7] [9,20], [3], ]
confused what"{1,#,2,3}"means? > read more on how binary tree is serialized on OJ.
OJ's Binary Tree Serialization:
The serialization of a binary tree follows a level order traversal, where '#' signifies a path terminator where no node exists below.
Here's an example:
1 / \ 2 3 / 4 \ 5
The above binary tree is serialized as"{1,2,3,#,#,4,#,#,5}".
思路:层次遍历二叉树,然后再进行逆序操作;
class Solution {
public:
vector<vector<int>> levelOrderBottom(TreeNode* root)
vector<vector<int>> res;
if (root == NULL)
return res;
queue<TreeNode*> q;
q.push(root);
while (q.size()>0)
vector<int> level;
for (int i = 0, n = q.size(); i<n; i++)
TreeNode* tmp = q.front();
q.pop();
level.push_back(tmp->val);
if (tmp->left)
q.push(tmp->left);
if (tmp->right)
q.push(tmp->right);
res.push_back(level);
reverse(res.begin(), res.end());
return res;
