电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » distinct-subsequences
2018-01-24 13:28:08     打赏
Given a string S and a string T, count the number of distinct subsequences ofT in S.
A subsequence of a string is a new string which is formed from the original string by deleting some (can be none) of the characters without disturbing the relative positions of the remaining characters. (ie,"ACE"is a subsequence of"ABCDE"while"AEC"is not).
Here is an example:
S ="rabbbit", T ="rabbit"
Return3.
思路:动态规划思想
dp[i][j]表示S中前i个字符构成的字符串包含T中前j个字符构成的字符串的长度,
当s[i-1]==T[j-1]时,则新的dp值可以说不使用第i个字符,却能构成T中j子串
[cpp] view plain copy
  1. class Solution {
  2. public:
  3.     int numDistinct(string S, string T)
  4.     {
  5.         int slen = S. length();
  6.         int tlen = T.length();
  7.
  8.         vector<vector<int>> dp;
  9.         vector<int> tmp(tlen+1, 0);
  10.         tmp[0] = 1;
  11.
  12.         for (int i=0; i<=slen; i++)
  13.         {
  14.             dp.push_back(tmp);
  15.         }
  16.
  17.         for (int i=1; i<=slen; i++)
  18.         {
  19.             for(int j=1; i<=tlen; j++)
  20.             {
  21.                 if (S[i-1]==T[j-1])
  22.                 {
  23.                     dp[i][j] = dp[i-1][j] + dp[i-1][j-1];
  24.                 }
  25.                 else
  26.                 {
  27.                     dp[i][j] = dp[i-1][j];
  28.                 }
  29.             }
  30.         }
  31.
  32.         return dp[slen][tlen];
  33.     }
  34.
  35. };
