电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » sum-root-to-leaf-numbers
2018-01-29 13:42:38     打赏
Given a binary tree containing digits from0-9only, each root-to-leaf path could represent a number.
An example is the root-to-leaf path1->2->3which represents the number123.
Find the total sum of all root-to-leaf numbers.
For example,
    1
  2   3
The root-to-leaf path1->2represents the number12.
The root-to-leaf path1->3represents the number13.
Return the sum = 12 + 13 =25.
思路:
先序遍历的思想(根左右)+数字求和(每一层都是上层和*10+当前值)
[cpp] view plain copy
  1. class Solution
  2. {
  3. public:
  4.
  5.     int sumNumbers(TreeNode* root)
  6.     {
  7.         int sum = 0;
  8.         if (root==NULL)
  9.         {
  10.             return sum;
  11.         }
  12.
  13.         return preorderSumNum(root, sum);
  14.     }
  15.
  16.     int preorderSumNum(TreeNode* root,  int sum)
  17.     {
  18.         if (root==NULL)
  19.         {
  20.             return 0;
  21.         }
  22.
  23.         sum = sum * 10 + root->val;
  24.         if (root->left==NULL && root->right==NULL)
  25.         {
  26.             return sum;
  27.         }
  28.
  29.         return preorderSumNum(root->left, sum) + preorderSumNum(root->right. sum);
  30.     }
  31. };
