Given a string s, partition s such that every substring of the partition is a palindrome.
Return the minimum cuts needed for a palindrome partitioning of s.
For example, given s ="aab",
Return1since the palindrome partitioning["aa","b"]could be produced using 1 cut.
计算字符串切割次数最小,转换成回文数
class Solution
public:
int minCut(string s)
int len = s.size();
//用于描述s.substr(k, j-k+1)是否能构成回文子串的矩阵
//flag[k][j]=true;能构成回文子串
vector<vector<bool>> flag(len, vector<bool>(len, false));
//用于记录最佳分割次数vector
//初始化状态下,长为i的子串的最佳分割次数:vec[i]=i-1;
vector<int> vec(len+1);
for (int i=0; i<len+1; i++)
vec[i] = i - 1;
//进入动态规划
for (int i=0; i<len; i++)
for (int j = 0; j <= i; j++)
//s中s[j][i]构成的子串(substr(j, i-j+1))能不能构成回文字符串
if (s[i] == s[j] && (i - j < 2 || flag[j+1][i-1])==true)
flag[j][i] == true;
//此时前i个字符串的最佳分割或者原分割次数v[i+1]
vec[i + 1] = min(vec[i+1], vec[j]+1);
return vec[len];
