电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » single-number-ii
single-number-ii
2018-01-31 13:10:23     打赏
Given an array of integers, every element appears three times except for one. Find that single one.
Note:
Your algorithm should have a linear runtime complexity. Could you implement it without using extra memory?
思路:若一个数出现三次,则其对应的二进制数每一位相加必为3或者0。统计数组中元素的每一位,若为3的倍数,所求数的二进制位对3取余为0
否则为1
[cpp] view plain copy
  1. class Solution
  2. {
  3. public:
  4.     int singleNumber(int A[], int n)
  5.     {
  6.         int bit[32] = {0};
  7.         int res = 0;
  8.         for (int i=0; i<32; i++)
  9.         {
  10.             for (int j = 0; j < n; j++)
  11.             {
  12.                 bit[i] += (A[j] >> i) & 1;
  13.                 res |= (bit[i]%3)<<i;
  14.             }
  15.         }
  16.
  17.         return res;
  18.     }
  19. };
