拿出板卡,一股正版的气息铺面而来...
创建库函数版工程模板
Stm32F0的标准库不好找,放个链接
然后创建模板,日常操作,截几个关键的图吧
这是必须的一些文件,勿忘,还有
然后我考虑用cubemx试试,但是感觉不太好用,可能是因为注释太多了吧。。。
移植OLED驱动程序
效果如下
主程序如下
部分驱动程序如下
#include "oled.h"
#include "oledfont.h"
#include "stm32f0xx.h"
#include "delay.h"
void OLED_Configuration(void)
GPIO_InitTypeDef GPIO_InitStructure;
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB,ENABLE);
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_OUT;//ÍÆÍìÊä³ö
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_Init(GPIOB,&GPIO_InitStructure);
GPIO_SetBits(GPIOB,GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15);
void OLED_Init(void)
OLED_RST_Set();
delay_ms(100);
OLED_RST_Clr();
delay_ms(100);
OLED_RST_Set();
OLED_WR_Byte(0xAE,OLED_CMD);//Set display off
OLED_WR_Byte(0x00,OLED_CMD);//set low column address
OLED_WR_Byte(0x10,OLED_CMD);//set high column address
OLED_WR_Byte(0x40,OLED_CMD);//set start line address Set Mapping RAM Display Start Line (0x00~0x3F)
OLED_WR_Byte(0x81,OLED_CMD);//Set contrast control
OLED_WR_Byte(0xCF,OLED_CMD);//Select1-256
OLED_WR_Byte(0xA4,OLED_CMD);//Disable entire display
OLED_WR_Byte(0xA6,OLED_CMD);//Set normal display
OLED_WR_Byte(0xAF,OLED_CMD);//Set display on
OLED_WR_Byte(0x20,OLED_CMD);//Set memory addressing mode
OLED_WR_Byte(0x02,OLED_CMD);//Set page addressing mode
OLED_WR_Byte(0xA1,OLED_CMD);//Disable segment re-map
OLED_WR_Byte(0xA8,OLED_CMD);//Set multiplex ratio
OLED_WR_Byte(0x3F,OLED_CMD);//1/64 duty
OLED_WR_Byte(0xC8,OLED_CMD);//Set normal mode scan
OLED_WR_Byte(0xD3,OLED_CMD);//Set display offset
OLED_WR_Byte(0x00,OLED_CMD);//No offset
OLED_WR_Byte(0xDA,OLED_CMD);//Set COM pins hardware configuration
OLED_WR_Byte(0x12,OLED_CMD);//Alternative COM pin configuration
OLED_WR_Byte(0xD5,OLED_CMD);//Set display clock clock divide
OLED_WR_Byte(0x80,OLED_CMD);//100 frames/s
OLED_WR_Byte(0xD9,OLED_CMD);//Set pre-charge period
OLED_WR_Byte(0xF1,OLED_CMD);//Set pre-charge as 15 clocks,discharge as 1 clock
OLED_WR_Byte(0xDB,OLED_CMD);//Set Vcomh deselect level
OLED_WR_Byte(0x40,OLED_CMD);//~0.77xVcc
OLED_WR_Byte(0x8D,OLED_CMD);//Set DCDC
OLED_WR_Byte(0x14,OLED_CMD);//Enable DCDC (0x10 disable)
OLED_Clear(0);
OLED_Set_Address(0,0);
/................中间省略................./
void OLED_WR_Byte(uint8_t DATA,uint8_t CMD)
uint8_t i;
OLED_CS_Clr();
if(CMD)
{OLED_DC_Set();}
else
OLED_DC_Clr();
for(i=0;i<8;i++)
OLED_SCLK_Clr();
if(DATA&0x80)
{OLED_SDIN_Set();}
else
OLED_SDIN_Clr();
OLED_SCLK_Set();
DATA<<=1;
OLED_CS_Set();
OLED_DC_Set();
void OLED_Set_Address(uint8_t column,uint8_t page)
OLED_WR_Byte(OLED_PAGE_Address+page,OLED_CMD);
OLED_WR_Byte(OLED_LINE_Address_L+column%16,OLED_CMD);
OLED_WR_Byte(OLED_LINE_Address_H+column/16,OLED_CMD);
void OLED_ShowString(u8 x,u8 y,u8 *chr)
unsigned char j=0;
while (chr[j]!='\0')
{ OLED_ShowChar(x,y,chr[j]);
x+=8;
if(x>120){x=0;y+=2;}
j++;
}驱动代码网盘链接
https://pan.baidu.com/s/1adV97nYilo4b7PikCFnqBA
现在就做了这么多,因为F0的板子大家很少用,程序都得从F1的移植,所以有点麻烦
先就这么多吧,告辞
