电子产品世界 » 论坛首页 » 高校专区 » 坤创E-Geek/天科大新电社 » 求助!DS18b20测温度 数码管显示 温度跳动不正常
共6条 1/1 1 跳转至
2019-01-24 14:17:26     打赏
如图,在测试ds18b20时 ,温度跳到25.0以后自动变成00.4,然后01.4,02.4,03.4
代码如下
#include<reg52.h>
#include<intrins.h>
typedef unsigned char u8;
typedef unsigned int u16;
sbit ds=P2^2;
sbit ser=P2^7;
sbit srclk=P2^6;
sbit rclk=P2^5;
bit flag;
unsigned char code smgduan[]={0x3f,
  0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,
  0x77,0x7c,0x39,0x5e,0x79,0x71};
   unsigned char code smgwei[]={0xfe,
  0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
void delayms(u16 n);
void TempDelay(u16 us);
  void send_595(u8 dat);
void ds_reset()
 ds=1;
 _nop_();
 ds=0;
 TempDelay(80);//520us
 ds=1;
 TempDelay(5);
 if(ds==0)
  flag=1;
 else
  flag=0;
 TempDelay(20);
 ds=1;
bit ds_read_bit()
 bit dat;
 ds=0;
 _nop_();
 _nop_();
 ds=1;
 _nop_();
 dat=ds;
 TempDelay(12);
 return dat;
u8 ds_read_byte()
 u8 i,j,value;
 for(i=0;i<8;i++)
  j=ds_read_bit();
  value=(j<<7)|(value>>1);
 return value;
void ds_write_byte(u8 dat)
 u8 i,onebit;
 for(i=0;i<8;i++)
  onebit=dat&0x01;
  if(onebit)    //?1
   ds=0;
   TempDelay(1);
   ds=1;
   _nop_();
  else  //?0
   ds=0;
   TempDelay(11);
   ds=1;
   _nop_();
  dat>>=1;
u8 get_temperature()
 u16 temp,temp1;
 u8 a,b;
  ds_reset();
 ds_write_byte(0xcc);
 ds_write_byte(0x44);
 ds_reset();
 ds_write_byte(0xbe);
 a=ds_read_byte();
 b=ds_read_byte();
 temp=b;
 temp<<=8;
 temp|=a;
 temp1 = temp*0.0625;
 temp=temp1*10+0.5;
 return temp ;
void main()
  {   u16 j;
   while(1){
   j=get_temperature();
     send_595(smgwei[0]);
   send_595(smgduan[j/1000]);
   rclk=0;
   rclk=1;
   delayms(1);
      send_595(smgwei[1]);
   send_595(smgduan[j%1000/100]);
   rclk=0;
   rclk=1;
   delayms(1);
      send_595(smgwei[2]);
   send_595(smgduan[j%100/10]);
   rclk=0;
   rclk=1;
      delayms(1);
    send_595(smgwei[3]);
   send_595(0X80);
   rclk=0;
   rclk=1;
   delayms(1);
    send_595(smgwei[4]);
   send_595(smgduan[j%10]);
   rclk=0;
   rclk=1;
   delayms(1);
    send_595(smgwei[5]);
   send_595(smgduan[12]);
   rclk=0;
   rclk=1;
   delayms(1);
  void delayms(u16 n)
    u8 i;
 while(n--)
 for(i=0;i<113;i++);
  void TempDelay(u8 us)
   while(us--);
    u8 i;
  for(i=0;i<8;i++)
    if(dat&0x80)
    ser=1;
   else
    ser=0;
   srclk=0;
      srclk=1;
   dat=dat<<1;
关键词: DS18b20
2019-01-24 16:53:41     打赏
首先,你的1602的init()函数写在while大循环里面是不合理的,不然每次循环都要对1602初始化;
其次,get_temperature()函数里面的delay(1000)没有必要写;
再者,请具体描述您的问题,越详细越好,有图最好,请在下方回复...
2019-01-24 17:05:42     打赏
  你的温度传感器程序并没有任何问题,那么我想问:你的硬件方面是不是有问题,你温度传感器接好了吗,你要根据原理图接好硬件。如果硬件有问题,数值不动是很正常的。
  另外提两个建议:
  1、蓝桥杯不需要LCD1602,着重点在数码管上。
  2、养成模块化编程的好习惯,不然代码多了之后就会很乱
2019-01-24 17:08:16     打赏
是显示85吗?
2019-01-24 21:43:31     打赏
你的数据处理有问题,这一句: temp=temp1*10+0.5;  不需要。
直接返回temp1值
在主函数里面赋值分别为:
j/100;
j%100/10;
j%100%10;
去掉小数部分
蓝桥杯不需要温度小数处理,况且你这小数处理是不对的,若想用小数,那就去网上看看人家怎么数值转换的
2020-06-15 07:35:54     打赏
请问你的是哪里出的问题,我现在也是同样的,显示到25之后就变为0.4了
共6条 1/1 1 跳转至
