Linux函数:pthread_mutex_lock()
Prolog
This manual page is part of the POSIX Programmer's Manual. The Linux implementation of this interface may differ (consult the corresponding Linux manual page for details of Linux behavior), or the interface may not be implemented on Linux.
Name
pthread_mutex_lock, pthread_mutex_trylock, pthread_mutex_unlock - lock and unlock a mutex
Synopsis
#include <pthread.h>
int pthread_mutex_lock(pthread_mutex_t *mutex);
int pthread_mutex_trylock(pthread_mutex_t *mutex);
int pthread_mutex_unlock(pthread_mutex_t *mutex);
Description
The mutex object referenced by mutex shall be locked by calling pthread_mutex_lock(). If the mutex is already locked, the calling thread shall block until the mutex becomes available. This operation shall return with the mutex object referenced by mutex in the locked state with the calling thread as its owner.
If the mutex type is PTHREAD_MUTEX_NORMAL, deadlock detection shall not be provided. Attempting to relock the mutex causes deadlock. If a thread attempts to unlock a mutex that it has not locked or a mutex which is unlocked, undefined behavior results.
If the mutex type is PTHREAD_MUTEX_ERRORCHECK, then error checking shall be provided. If a thread attempts to relock a mutex that it has already locked, an error shall be returned. If a thread attempts to unlock a mutex that it has not locked or a mutex which is unlocked, an error shall be returned.
If the mutex type is PTHREAD_MUTEX_RECURSIVE, then the mutex shall maintain the concept of a lock count. When a thread successfully acquires a mutex for the first time, the lock count shall be set to one. Every time a thread relocks this mutex, the lock count shall be incremented by one. Each time the thread unlocks the mutex, the lock count shall be decremented by one. When the lock count reaches zero, the mutex shall become available for other threads to acquire. If a thread attempts to unlock a mutex that it has not locked or a mutex which is unlocked, an error shall be returned.
If the mutex type is PTHREAD_MUTEX_DEFAULT, attempting to recursively lock the mutex results in undefined behavior. Attempting to unlock the mutex if it was not locked by the calling thread results in undefined behavior. Attempting to unlock the mutex if it is not locked results in undefined behavior.
The pthread_mutex_trylock() function shall be equivalent to pthread_mutex_lock(), except that if the mutex object referenced by mutex is currently locked (by any thread, including the current thread), the call shall return immediately. If the mutex type is PTHREAD_MUTEX_RECURSIVE and the mutex is currently owned by the calling thread, the mutex lock count shall be incremented by one and the pthread_mutex_trylock() function shall immediately return success.
The pthread_mutex_unlock() function shall release the mutex object referenced by mutex. The manner in which a mutex is released is dependent upon the mutex's type attribute. If there are threads blocked on the mutex object referenced by mutex when pthread_mutex_unlock() is called, resulting in the mutex becoming available, the scheduling policy shall determine which thread shall acquire the mutex.
(In the case of PTHREAD_MUTEX_RECURSIVE mutexes, the mutex shall become available when the count reaches zero and the calling thread no longer has any locks on this mutex.)
If a signal is delivered to a thread waiting for a mutex, upon return from the signal handler the thread shall resume waiting for the mutex as if it was not interrupted.
Return Value
If successful, the pthread_mutex_lock() and pthread_mutex_unlock() functions shall return zero; otherwise, an error number shall be returned to indicate the error.
The pthread_mutex_trylock() function shall return zero if a lock on the mutex object referenced by mutex is acquired. Otherwise, an error number is returned to indicate the error.
Errors
The pthread_mutex_lock() and pthread_mutex_trylock() functions shall fail if:
EINVAL
The mutex was created with the protocol attribute having the value PTHREAD_PRIO_PROTECT and the calling thread's priority is higher than the mutex's current priority ceiling.
The pthread_mutex_trylock() function shall fail if:
EBUSY
The mutex could not be acquired because it was already locked.
The pthread_mutex_lock(), pthread_mutex_trylock(), and pthread_mutex_unlock() functions may fail if:
EINVAL
The value specified by mutex does not refer to an initialized mutex object.
EAGAIN
The mutex could not be acquired because the maximum number of recursive locks for mutex has been exceeded.
The pthread_mutex_lock() function may fail if:
EDEADLK
The current thread already owns the mutex.
The pthread_mutex_unlock() function may fail if:
EPERM
The current thread does not own the mutex.
These functions shall not return an error code of [EINTR].
The following sections are informative.
reference: https://linux.die.net/man/3/pthread_mutex_lock
