This application note describes the design of the PWM buck-boost converters using ROHM’s AC/DC converter IC BM2Pxxx series devices. It explains the selection of external components and provides PCB layout guidelines. Please note that all performance characteristics have to be verified. They are not guaranteed by the PCB layout shown here.
● Description
The BM2Pxxx series of ICs are AC/DC converters for PWM switching, incorporating a built-in starter circuit having withstanding voltage of 650V and a switching MOSFET having withstanding voltage of 650V. With ROHM’s original high-speed switching MOSFET built inside, it is possible to increase the peak current, contributes to miniaturization of the magnetic components. BM2Pxxx supports both isolated and non-isolated circuits, enabling simpler design of various types of low-power converters.
● Key features
- PWM frequency 65kHz (with frequency-hopping function)/ Current mode
- Burst-operation and frequency reduction functions when load is light
- Built-in 650V starter circuit / Built-in 650V switching MOSFET
- VCC pin under-voltage protection/Over-voltage protection
- SOURCE pin Open/ Short protection, Leading-Edge-Blanking function
- Per-cycle over-current limiter function
- Over-current limiter AC correction function
- Soft-start function
● BM2Pxxx Series line-up
1. Design Example of Non-Isolated Type Buck-Boost Converter DCM (Discontinuous Conduction Mode)
……未完待续……
点击此处,免费查看完整版“BM2P0XX系列 PWM升压转换器的技术设计”
