电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 采用arduinoNano制作的一款简洁型金属探测器
共5条 1/1 1 跳转至
2020-11-26 21:11:24     打赏
金属探测器? 大家估计会喜欢吧?!
如下是电路图和源码,大家可以按此制作DIY
BOM清单:
R1 = 330 Ω, resistor
R2 = 1 KΩ, resistor
C1 = 10nF, ceramic capacitor
D1 = 1N4148, diode
BUZ1 = Buzzer
LED1 = 5mm any color LED
Arduino UNO Board or equivalent
成品图:
#define vinPin A5
#define buz 9
#define pulsePin A4
#define led 10
long sumExpect=0; //running sum of 64 sums
long ignor=0;   //number of ignored sums
long diff=0;        //difference between sum and avgsum
long pTime=0;
long buzPeriod=0;
void setup()
  Serial.begin(9600);
  pinMode(pulsePin, OUTPUT);
  digitalWrite(pulsePin, LOW);
  pinMode(vinPin, INPUT);
  pinMode(buz, OUTPUT);
  digitalWrite(buz, LOW);
  pinMode(led, OUTPUT);
void loop()
  int minval=1023;
  int maxval=0;
  long unsigned int sum=0;
  for (int i=0; i<256; i++)
    //reset the capacitor
    pinMode(vinPin,OUTPUT);
    digitalWrite(vinPin,LOW);
    delayMicroseconds(20);
    pinMode(vinPin,INPUT);
    applyPulses();
    //read the charge of capacitor
    int val = analogRead(vinPin); //takes 13x8=104 microseconds
    minval = min(val,minval);
    maxval = max(val,maxval);
    sum+=val;
    long unsigned int cTime=millis();
    char buzState=0;
    if (cTime<pTime+10)
      if (diff>0)
        buzState=1;
      else if(diff<0)
        buzState=2;
    if (cTime>pTime+buzPeriod)
      if (diff>0)
      buzState=1;
      else if (diff<0)
      buzState=2;
      pTime=cTime;
    if (buzPeriod>300)
    buzState=0;
    if (buzState==0)
      digitalWrite(led, LOW);
      noTone(buz);
    else if (buzState==1)
      tone(buz,2000);
      digitalWrite(led, HIGH);
    else if (buzState==2)
      tone(buz,500);
  //subtract minimum and maximum value to remove spikes
  sum-=minval;
  sum-=maxval;
  if (sumExpect==0)
  sumExpect=sum<<6; //set sumExpect to expected value
  long int avgsum=(sumExpect+32)>>6;
  diff=sum-avgsum;
  if (abs(diff)<avgsum>>10)
    sumExpect=sumExpect+sum-avgsum;
    ignor=0;
  else
    ignor++;
  if (ignor>64)
    sumExpect=sum<<6;
    ignor=0;
  if (diff==0)
    buzPeriod=1000000;
  else
  buzPeriod=avgsum/(2*abs(diff));
void applyPulses()
    for (int i=0;i<3;i++)
      digitalWrite(pulsePin,HIGH); //take 3.5 uS
      delayMicroseconds(3);
      digitalWrite(pulsePin,LOW);  //take 3.5 uS
关键词: arduino     探测器     金属探测器
2020-11-26 21:19:29     打赏
电路,很简洁嘛!
2020-11-26 21:22:58     打赏
不知道探测距离有多远?
2020-11-26 21:26:26     打赏
请问电感线圈 L1 如何制作或设计?
2020-11-26 22:03:22     打赏
确实写的不错的
共5条 1/1 1 跳转至
