N 系列射频同轴连接器 SERIES RF COAXIAL CONNECTORS
N系列产品是一种螺纹连接的中功率连接器,它具有可靠性高,抗振性强、机械和电气性能优良等特点,广泛用于振动和环境恶劣条件下的无线电设备和仪器及地面****系统连接射频同轴电缆。
Power person who join in the what series of N products join by one whorl, it has the characteristic of reliable and strong ant-vibration nature, machinery and electric performance finely. It is used in vibration and environment abominable radio equipment of terms and instrument and ground launch system join the coaxial cable of the radio frequency extensively.
主要技术特性 TECHNICAL CHARACTERISTICS
温度范围 Temp.range -65~+165°C (PE Cable)
振 动 Vibration MIL-STD-202, Method 213
特性阻抗 Impedance 50Ω
频率范围 Frequency Range DC~11GHz
工作电压 Working Voltage 1000V max (有效值)
耐 压 Withstand Voltage 2500V rms (海平面最小值)
接触电阻 Contact resistance
内导体之间 Center Contact ≤ 1 mΩ
外导体之间 Outer Contact ≤ 1 mΩ
绝缘电阻 Insulation resistance ≥ 5000 MΩ
电压驻波比 VSWR 直式 Straight ≤ 1.15
弯式 Right angle ≤ 1.25
耐用性 Durability(mating) ≥500次(cycles)
材料与涂覆 MATERIAL & PLATING
壳体 shell 黄铜 brass 镀亮镍 nickel plated
插针 contact pin 黄铜 brass 镀硬金 gold plated
弹性接触件elastic contact铍青铜 beryllium 镀硬金 gold plated
插孔 socket 铍青铜或锡青铜beryllium or tin brass 镀硬金 gold plated
绝缘体 insulator 聚四氟乙烯 PTFE
压接套 crimp ferrule 铜合金 copper alloy 镀镍或镀金 nickel or gold plated
o型密封件o-ring sealing 硅橡胶 6146 silastic
适用技术标准 APPLICABLE STANDARD
MIL-C-39012;
CECC 22210;
IEC 60169-16
共1条
N系列射频同轴连接器简介
关键词: 连接器
共1条
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
