如下是Introspect DP/EDP Pattern Generator and Analyzer 的主要功能介绍,目前包括苹果、高通、集创北方、Himax等等公司都有在使用,若您感兴趣,还请和我联系,谢谢。
SV5C DP/EDP Pattern Generator Key Features:可任意调节DP/eDP的各种参数/码型,覆盖DP/eDP协议物理层至协议层的产品测试验证,包含:Jitter Injection、Skew、电压幅值、时序以等等. • Protocol: supports Embedded DisplayPort (eDP) up to v1.4 and Display Port (DP) up to v1.4• Data Rates: up to 10.5 Gbps with a fully continuous range of data rates• Lane Count: configurable from 1 to 4 lanes per port (L0 to L3) plus auxiliary channel (AUX)• Pattern Generation: full video frame generation with 8 GBytes of pattern memory• Analog Controls: voltage amplitude and common mode voltage, each per lane• Signal Impairments: jitter injection, sinusoidal voltage noise injection, perwire timing skew
SV5C DP/EDP Analyzer Key Features:• Protocol: supports Embedded DisplayPort (eDP) up to v1.4 and Display Port (DP) up to v1.4• Data Rates: up to 10.5 Gbps with a fully continuous range of data rates• Lane Count: configurable from 1 to 4 lanes per port (L0 to L3) plus auxiliary channel (AUX)• Protocol Analysis: full video frame capture with 8 GBytes of pattern memory• Eye Diagram Analysis: deep bit error rate measurement and eye margining
