通过数码管显示数字变化,首先需要将跳线帽拔掉
进入syscfg进行初始化GPIO管脚和定时器,分别配置
PA27==>HC595_DAT,
PA26==>HC595_SLK,
PA13==>HC595_RLK,
在代码中编写HC595驱动函数:
uint16_t tempval =456;
uint8_t TimerCnt = 0 ;
unsigned char Disp_DX[16] ={ 0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90, 0x8C, 0xBF, 0xC6, 0xA1, 0x86, 0xFF };
unsigned char Disp_PX[8] = {1,2,3,4,5,6,7,8};
#define HC595_DAT(x) ((x)?(DL_GPIO_setPins(GPIOA_HC595_PORT,GPIOA_HC595_HC595_DAT_PIN)) : (DL_GPIO_clearPins(GPIOA_HC595_PORT,GPIOA_HC595_HC595_DAT_PIN)))
#define HC595_CLK(x) ((x)?(DL_GPIO_setPins(GPIOA_HC595_PORT,GPIOA_HC595_HC595_SLK_PIN)) : (DL_GPIO_clearPins(GPIOA_HC595_PORT,GPIOA_HC595_HC595_SLK_PIN)))
#define HC595_RCK(x) ((x)?(DL_GPIO_setPins(GPIOA_HC595_PORT,GPIOA_HC595_HC595_RLK_PIN)) : (DL_GPIO_clearPins(GPIOA_HC595_PORT,GPIOA_HC595_HC595_RLK_PIN)))
void Display_0ut()
HC595_RCK(0);
delay_cycles(32);
HC595_RCK(1);
delay_cycles(32);
void HC595_WriteData(unsigned char data)
unsigned char i;
for(i=0;i<8;i++)
if(data & 0x80)
HC595_DAT(1);
else
HC595_DAT(0);
data <<= 1;
HC595_CLK(0);
delay_cycles(32);
HC595_CLK(1);
delay_cycles(32);
void HC595_Send_Data(uint8_t dis_num,uint8_t dis_bit)
HC595_WriteData(dis_num);
HC595_WriteData(1<<dis_bit);
Display_0ut();
void Disp_Data(uint16_t u16DataH)
uint16_t templ,tempH;
uint8_t num_q,num_b,num_s,num_g;
tempH = u16DataH;
num_q = tempH/1000;
num_b = tempH/100%10;
num_s = tempH/10%10;
num_g = tempH%10;
HC595_Send_Data(Disp_DX[num_q],7);
HC595_Send_Data(Disp_DX[num_b],6);
HC595_Send_Data(Disp_DX[num_s],5);
HC595_Send_Data(Disp_DX[num_g],4);
void TIMER_0_INST_IRQHandler(void)
switch(DL_TimerG_getPendingInterrupt(TIMER_0_INST))
case DL_TIMER_IIDX_ZERO:
TimerCnt++;
if(TimerCnt >=100)
TimerCnt=0;
tempval--;
if(tempval>500)tempval=0;
break;
default:
break;
}在主函数中调用:
