ads1.2 浮动license 服务安装在 sun unix 服务器上,
在PC上,设license 的环境变量,然后运行ARM develop suit ,可以从服务器上拿到license.
可是在同一PC的cygwin上,设license 的环境变量,然后运行ads1.2进行编译,出现错误:
得不到license,socket 呼叫失败. 以下是错误信息:
Serious error: C3397E: Cannot obtain license for compiler with license version >= 1.2: socket() call failed Feature: compiler License path: 8224@132.147.203.3
FLEXlm error: -57,17. System Error: 10106 "Invalid (inconsistent) license key" For further information, refer to the FLEXlm End User Manual, available at "www.globetrotter.com".
请问各位如何解决.
谢谢!!
