电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » [求助]用TORNADO FOR COLDFIRE 编译程序自带的BSP时老出错
[求助]用TORNADO FOR COLDFIRE 编译程序自带的BSP时老出错??Program too big to fit in memory!
2006-03-30 17:24:23     打赏
dcc -c -g -tMCF5307FS:vxworks55 -Xmismatch-warning=2 -Xansi -Xstrings-in-text=0 -ew1554 -X
size-opt -Xpreprocess-assembly -Wa,-Xmnem-all -c -I.. -IC:\Tornado2.2\target\config\m5272c
3 -IC:\Tornado2.2\target\h -IC:\Tornado2.2\target\config\comps\src -IC:\Tornado2.2\target\
src\drv -DCPU=MCF5200 -DTOOL_FAMILY=diab -DTOOL=diab -DPRJ_BUILD -Xmemory-is-volatile C:\
Tornado2.2\target\config\m5272c3\sysALib.s -o sysALib.o
Invalid keyboard code specified
dcc -c -g -tMCF5307FS:vxworks55 -W:c:,-Xmismatch-warning=2 -ew1554,1551,1552,1086,1047,154
7 -Xclib-optim-off -Xansi -Xstrings-in-text=0 -Wa,-Xsemi-is-newline -ei1516,1643,1604 -Xlo
cal-data-area-static-only -ew1554 -Xsize-opt -I.. -IC:\Tornado2.2\target\config\m5272c3 -I
C:\Tornado2.2\target\h -IC:\Tornado2.2\target\config\comps\src -IC:\Tornado2.2\target\src\
drv -DCPU=MCF5200 -DTOOL_FAMILY=diab -DTOOL=diab -DPRJ_BUILD -Xmemory-is-volatile C:\Torn
ado2.2\target\config\m5272c3\sysLib.c -o sysLib.o
不知道
Program too big to fit in memory为什么会这样???这可是自带的BSP呀!
关键词: 求助     TORNADO     COLDFIRE     编译程序
2006-03-30 21:14:00     打赏
请教一下“雷”斑竹吧,呵呵
