各位老大:
小弟用SDT2.51编译时出现如下错误信息:
Fatal Error: "..\src\xx.c"; line 1236 Failure of internal consistency check displacement out of range 4096 Internal inconsistency: either resource shortage or compiler fault. If you cannot alter your program to avoid this failure, please contact your supplier
在编译选项中去除debug control中的enable debug table generation后编译通过。
但这样没有debug table ,我无法单步调试。
请教大虾,是何原因,如何解决?
