44B0 44B0采集数据问题,高手帮忙,谢谢
用S3C44B0采集一个极易变化的数据,因此想用74LS573进行数据锁存,但是74LS573是5V 高电平,ARM扳引脚是3.3V。除了光偶隔离之外,有没更好的办法呢?因为八个数据线,要光隔八个,太麻烦了,谢谢
答 1:
随便加个buffer吧
答 2:
74LV57374LV573; Octal D-type transparent latch (3-State)
The 74LV573 is a low-voltage Si-gate CMOS device that is pin and function compatible with 74HC/HCT573. The 74LV573 is an octal D-type transparent latch featuring separate D-type inputs for each latch and 3-State outputs for bus oriented ...
答 3: 74hc系列的可以工作在3V
答 3: 74hc系列的可以工作在3V
| 为遥控小车巧添功能被打赏¥26元 | |
