2210,UC,OS 在2210上移植UC/OS中,有关邮箱和消息队列使用中的问题!
UC/OS-II 我的程序中邮箱发送消息正确,但等待接收的却接收不到,接收的任务优先级高。应该可以接收到呀!请问是什么原因呢?谢谢了!
任务之间发送消息,接收者总接收不到。但同一个任务里发送时可以接收到 答 1: 程序#include "config.h"
#define ENGINE_OIL_PERS_OK 0x01
#define ENGINE_OIL_TEMP_OK 0x02
#define ENGINE_START 0x04
#define TASK_STK_SIZE 64
OS_STK TaskStk[TASK_STK_SIZE];
OS_STK TaskStartStk[TASK_STK_SIZE];
OS_STK TaskBeenStk[TASK_STK_SIZE];
OS_STK TaskOutStk[TASK_STK_SIZE];
OS_EVENT *Uart0Mbox;
OS_FLAG_GRP *EngineStatus;
void Uart0Send(uint8 *dat,uint8 num);
uint8 Uart0Recive(uint8 num);
void TaskStart(void *pdata);
void TaskOut(void *pdata);
void TaskBeen(void *pdata);
int main(void)
OSInit();
Uart0Mbox=OSMboxCreate(NULL);
if(Uart0Mbox==NULL)
while(1);
OSTaskCreate(TaskStart,(void *)0,&TaskStartStk[TASK_STK_SIZE-1],0);
OSStart();
return 0;
uint8 err,err1,err2,err3;
uint8 *dat;
EngineStatus = OSFlagCreate(0x00,&err3);
TargetInit();
OSTaskCreate(TaskOut,(void *)0,&TaskOutStk[TASK_STK_SIZE-1],12);
OSTaskCreate(TaskBeen,(void *)0,&TaskBeenStk[TASK_STK_SIZE-1],11);
abb:
OSFlagPost(EngineStatus,ENGINE_OIL_PERS_OK,OS_FLAG_SET,&err);
if(err!=OS_NO_ERR)
goto abb;
for(;;)
dat=(uint8 *)OSMboxPend(Uart0Mbox,10,&err1);
Uart0Send(dat,5);
OSFlagPost(EngineStatus,ENGINE_OIL_PERS_OK,OS_FLAG_SET,&err2);
uint8 Flag;
uint8 *dat;
pdata=pdata;
for(;;)
Flag=OSFlagPend(EngineStatus,ENGINE_OIL_PERS_OK,OS_FLAG_WAIT_SET_ALL,20,&err);
if(err==OS_NO_ERR)
dat=(void *)Uart0Recive(5);
if(*(dat+4)==0xFF)
OSFlagPost(EngineStatus,ENGINE_OIL_TEMP_OK,OS_FLAG_SET,&err1);
err2=OSMboxPost(Uart0Mbox,(void *)dat);
if(err2==OS_NO_ERR)
OSFlagPost(EngineStatus,ENGINE_OIL_PERS_OK,OS_FLAG_CLR,&err3);
uint8 err;
pdata=pdata;
for(;;)
OSFlagPend(EngineStatus,ENGINE_OIL_TEMP_OK,OS_FLAG_WAIT_SET_ALL+OS_FLAG_CONSUME,0,&err);
OS_ENTER_CRITICAL();
PWMTCR=0x09; //启动PWM
OS_EXIT_CRITICAL();
OSTimeDly(OS_TICKS_PER_SEC*5);
PWMTCR=0x09;
OS_EXIT_CRITICAL();
int main(void)
OSInit();
if(Uart0Mbox==NULL)
while(1);
OSStart();
return 0;
uint8 *dat;
TargetInit();
abb:
if(err!=OS_NO_ERR)
goto abb;
for(;;)
Uart0Send(dat,5);
uint8 Flag;
uint8 *dat;
pdata=pdata;
for(;;)
if(err==OS_NO_ERR)
if(*(dat+4)==0xFF)
if(err2==OS_NO_ERR)
uint8 err;
pdata=pdata;
for(;;)
OS_EXIT_CRITICAL();
PWMTCR=0x09;
OS_EXIT_CRITICAL();
